Question about Whirlpool Refrigerators
I have a Whrilpool Fridgerator with the freezer in the bottom I have to clean ice out of the freezer that forms every 3 days can any one tell me what the problem is ty
  • 31 Answers
Probably heating element in freezer is broken.
Remove power and defrost. Remove wall panels in back of freezer to Check heater element behind panels With ohm meter should read 20 ohms or less. You could remove it and bring it to a local repair shop and have them test it and if required order you a new one. If this does not work it may be the control board
Posted on Nov 07, 2013
catriver
  • 878 Answers
SOURCE: Ice forming in bottom of freezer
Rita, your drain hole is frozen over and when your refer goes into defrost the water is running out into the cabinet instead of down the drain hole. Remove the evaporator cover and poor some boiling water in the evaporator drip pan. This should melt the ice and clear the drain hole....Catriver...post back.
Posted on Aug 17, 2006
SOURCE: FF200EP Fridge Freezer - water
I had the same problem, the fridge would leak overnight (usually) I found with some more searching the answer..... try it at you own risk!
Here are 2 detailed answers depending on your circumstances/technical ability....Turn off fridge....
1. Defrost fridge...catch all the water
or
2. Work quickly....
Remove drawers, at the back of the fridge there is a panel with 5 phillips screws (note that there are long and short screws). Remove the screws and the panel. (if you chose the second option then this will be "frozen in place" so you will get crunching noise when you peel it away - so be careful when removing it). At the top of the panel is a connector that powers the fan, squeeze the 2 sides in to remove. This will allow the panel/ducting to be removed from the fridge. (If you chose option 2 you will now probably see a large lump of ice over the drain hole).
Remove ice or debris from drain hole, re-asssmble not forgetting to connect the fan again!!!) then repower the fridge following the instructions as you will get the alarms... the fridge cools and the warning lights dissapear.......24 hours on mine is OK!
Mal Function
Posted on Dec 28, 2008
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Refrigerator Freezer has ice forming in the bottom
I believe you just described a defrost condensate blockage that is causing the leaking. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan, water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Posted on Nov 19, 2009
SOURCE: Forming ice in the freezer vent going to bottom
It could also be your defrost heater. Look in side your fridge at the adjustment knob. It is in a box attached to the ceiling of your fridge. Look under this and you should see a plastic screw. Turn this screw until the motor cuts off. Leave it off for about 30 minutes. If motor turns back on then the defrost timer is working. The defrost heater is in the back panel of the freezer. The defrost heater looks like a long tube that runs under the freezer coils and half way up both sides. If after turning the screw on the defrost timer and the fridge doesn't turn back on then it is the defrost timer. The time is inside the box the adjustment knob is on.
Posted on Apr 25, 2010
I have a maytag bottom freezer refrigerator model# MFF2558VB3 that is forming a sheet of ice on the bottom.
Type in the search engine on your computer Refrigerator Repair-Ice in the freezer- Whirlpool, Maytag, Kenmore
Do that and it should give you your answer.
Jun 19, 2017 | Maytag Refrigerators
The freezer is on the bottom of the fridge...and the bottom part of the freezer is forming a block of ice..just over 1 yr ago that i purchased the fridge. i tried moving things in the fridge forward so...
There is normally a "thing" that controls the auto defrost I had a freezer that started so it this out of the blue. Some how that "thing" got unplugged. It was in the freezer behind a panel in the back by the light.
May 28, 2017 | Maytag MBR2562HES Stainless Steel Bottom...
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Model FRS26ZRF---Water forming ice block on bottom of freezer
I ll tell you whats going to happen . the clean coils will helt it to freeze up sooner . that part is good / but the ice problem is a defrost problem caused by the heater or defrost control failure . so keep on working your not done yet .. .you will find the heater and defrost terminater inside the fack of freezer .. mm
Jul 06, 2010 | Frigidaire FRS26KF5C Side by Side...
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice forming on bottom of freezer
Switch off the power
First keep all the items out
Open the door and remove all the fixers
let the whole body will be get dry
check the freezer is there any gap between the door
Let me know if your problem is solved and rate me as FIXYA!
Mar 07, 2008 | Kenmore 73503 Stainless Steel Bottom...
Aug 16, 2006 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
