Wavelab 4 steinberg not working with vista
The program stops running when trying to save or insert a file. what do i do?
2 Suggested Answers
SOURCE: stops my work!!!
I NOW THIS PROBLEM >>
AND I FIX IT >>
PLEESE GO TO UR LANGUGE IN CONTROL PALNAL >>
AND TRY TO FIX UR LANGUGE THERE ..
CAUSE IT NEED TO DO THAt
Posted on Dec 08, 2008
Cannot open Wave Device for recording. Are you sure your audio card supports the currently specified sample rate and/or bit resolution?
It's basically saying that your inbuilt sound card might not be compatible with the software. Check the software specifications and then look at your sound card specifications. You can also select a different bit rate under the recording options in the software. For example many MP3 files are recorded at 320, but you can reduce it to say 128. This might allow the an older type sound card to work with the software.
May 21, 2016 | Steinberg Media Technologies WaveLab...
License activayion code
The activation key will be on the cd or in the cd case or on
the box it came in. It is a 5 block of 4 numbers and letters separated by dashes.
May 19, 2013 | Cubase Steinberg WaveLab Elements 7...
How do I uninstall vst plugins from Cubase 4 ( windows xp )
If you'd like to remove them from your computer you would need to do one of the following 2 things:
1. if they were installed from a disc or .exe you can use the add remove program option from the control panel of your pc...once in their look for the name of either the manufacturer or the plugin name and select remove.
2. If they were installed from simple dragging and dropping of the .dll or folder files then youll need to go to the main plugin location and physically delete the files. In most cases this location can be found in one or more places depending on your operating system:
1. C-->program files--> steinberg -->vstPlugins
or C-->program files-->vstplugins
2. C-->x86-->program files--> steinberg -- vstplugins
or C-->x86-->program files-->vstplugins
Oct 15, 2012 | Steinberg Cubase 4 ( Windows / Macintosh )...
How can I get wavelab 4 to work in windows 7?
You can run xp on a virtual machine (VMware or VirtualBox, e.g.) and your program, inside.
On the other hand, Steinberg released version 6 of WaveLab that is compatible with W7.
Mar 22, 2011 | Steinberg WaveLab 4.0 Full Version for PC
0x8ac70013 msn video call are not working
Solution A: If you using McAfee Antivirus, the following steps will configure SiteAdvisor to stop monitoring windows live messenger. Go try solution B if you are NOT using McAfee Antivirus.
1. Navigate to the following folder:
Windows XP/2000/Vista (32-bit): C:\Program Files\McAfee\SiteAdvisor
Windows Vista (64-bit): C:\Program Files (x86)\McAfee\SiteAdvisor
2. Right-click on the file sasets.ini and choose Open With, then select Notepad.
3. Locate the section titled [msnmsgr.exe].
4. Change Enabled=1 to Enabled=0.
5. Click File and select Save.
6. Close sasets.ini and restart your computer for changes to take effect.
Solution B: I am using XP with NOD32, using the latest version 2009 (Build 14.0.8117.416) and here is the solution that works for me,
1. Sign off and Exit messenger
2. Go to C:\Program Files\Windows Live\Messenger
3. Right click on file "msnmsgr.exe", select "Properties", a new window of msnmsgr.exe Properties will pop up.
4. Under "Compatibility" tab, look for "Compatibility mode", if the box "Run this program in compatibility mode for" is checked and show window 2000. Go ahead un-check it.
5. Open messenger again and try to test the video call.
Mar 18, 2011 | Home
I have steinberg clean 4 & 5 but both versions only show CPF file choice .i want to save as wav.
On the File menu you will find an option named "Export Audiotrack as WAV" as well as "Export Audiotrack as MP3". This will allow you to Save or Export the files you create as either the .wav format or the .mp3 format. Check your Help file, specifically page 86, if you need further information.
Mar 17, 2011 | Pinnacle Steinberg Clean 4.0 (210100265)...
I have an m-audio fast track and have 10 sessions recorded. This is perhaps a foolish question, but what is the best software to load these 10 songs into to make a finished album. Thanks.
Do you want to layer the sessions and mix them together? Then Cubase is the best software.
http://www.steinberg.net/en/products/cubase/cubase6_why_cubase.html
OR
Do you just want to edit the sessions individually? Then Wavelab is the best software.
http://www.steinberg.net/en/products/wavelab/why_wavelab.html#c61447
Mar 15, 2011 | M-Audio Fast Track External Sound System
Firebox and cubase se not workin
https://www.steinberg.net/1069+M52087573ab0.html, If u have purchased the software,just go to this this link,register ur product. U will get the steinberg cubase customer care, just try contacting them and rectifying the problem, because this is too specific and technical.BEST OF LUCK!!!! THANK U!!!!
Jun 21, 2008 | Steinberg Cubase SE
Usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Apr 01, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
