Question about Splendide 2000S Vented Washer/Dryer
Washer will not fill. On display it says H20. Water is coming in the pipes in rv but not washer.
    Top Expert:
  • 4,292 Answers
Bad water solenoid
Posted on Sep 22, 2017
My aqualitis aqxxf149pi is displaying h20 error code, filling correctly at start of wash cycle but mid cycle starting to add excessive water before it goes on drain and spin resulting in flooding
H20 is a water warning. The machine THINKS it has no water coming in (Hence it continues to fill and fill because it can''t see the water). 99% of the time, this is a blocked rubber pipe that goes to the pressure sensor. Water in the drum fills the bottom of the rubber pipe and as the water rises, the air pressure in the pipe increases, which operates a bellows device in the pressure sensor. If the pipe is blocked, the pressure sensor won't operate and it will continue to try to fill until it times out. There COULD be a wire off the sensor or a wire that goes to the sensor loose on the main board, there could even be a failed component on the main board, but all of these scenarios are ar less likely than a blocked pressure sensor pipe. Take the lid off, pull the pipe off the bottom of the sensor, blow down it hard and this may well clear the blockage. Put the pipe back on the sensor and test. Come back if you need more advice
Aug 24, 2015 | Hotpoint Washing Machines
Just keeps filling at the start of program and displays H20
Your washer has a bad water valve or fill censor telling machine need more water then to much water sends a flood warning shuts down so will not flood your home look for small clear tube coming from tub to a type control hose may just came off
Mar 09, 2015 | Hotpoint Ultima WF860 Front Load Washer
Indesit washing machine showing H20
code showing h20 is the clue water is also known as h20,so your problem is the inlet valve letting the water into the back of your machine needs replaced or water pipe is kinked and no water is at the supply,. these valves are cheap at 10 dollars,adrian.....
Dec 20, 2014 | Indesit W 123 Front Load Washer
H20 symbol on display of hotpoint wf 860 washing machine
Pull off your washer mains cord from the wall. Turn off your wall faucet,, the valve on wall which allows water into the washer. (h2o means your washer is not receiving the most importing thing - water). Disconnect the pipes of the water from the wall. Check by opening the wall valve to see if the water flow is gud. Next fit back carefully. Then unscrew the other end of the hose/hoses at the entry point of your washer - remove the fine filters and clean out with an old tooth brush; clean inside the opening of inlet valve too carefully, check. Now re-fit the filters carefully and screw back the hoses. You are done now. It is advisable to close the wall valve when your washing is done, takes pressure off the machine valve.
Pl click if helped.....
Apr 05, 2013 | Hotpoint Ultima WF860 Front Load Washer
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
Machine keeps beeping. Filling and emptying with water and H20 is flashing in the digital display
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments for more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Set wash program ,wont start ,there is a tap on display plus it flashes up H2O
H20 means a water inlet problem.
Check the inlet pipe/s are not restricted or kinked.
Ensure that the pressure is adequate.
This cold weather has caused some washer hoses to freeze up.
Hope this helps.
Jan 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Splendide 2000S Vented Washer/Dryer Logo
50 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
isaac johny
isaac johny
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
