Question about Gateway Computers & Internet
Ntfs sys corrupt - Gateway Computers & Internet
  • 386 Answers
Hi Jennilynn,
Running an SFC scan repairs/replaces the corrupted system file.
-Restart your computer and tap on the F8 key until you reach the Advanced Boot Options menu.
-SelectSafe Mode with command prompt.
-TypeSFC /scannow (there is a space betweenC and /) at the command prompt.
I've used this fix before and it usually works. If it's still not working, give me a shout and I'd be happy o look more into it with you.
Thanks,
Gary
Posted on Oct 17, 2013
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
Windows did not start ,drivers missing
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer
Mar 03, 2011 | Computers & Internet
Ntfs is missing
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
Error code 0x00000024 (0x00190203, 0x871a6948, 0xc0000102, 0x00000000000)
This stop error means that your ntfs file system is corrupt (damage in the file system, bad hard drive data, corrupt SCSI or IDE drivers or a corrupt ntfs.sys file).
You should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS . You can download it from
http://www.geekswhoknow.com/files/ntfsinst.exe
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reinstall Windows and select the full format during the install
Nov 14, 2010 | Computers & Internet
I turn on my Eee pc and it says a file:system32\Drivers\Nfts.sys has corrupt or gone missing
I would take it to a local shop to get it fixed. If you have to ask, it is most likely beyond your skills.
This issue is known to be caused by one or more of the below causes.
  1. Other software or malware corrupts or deletes the ntfs.sys file.
  2. Overclocking / heat related issues.
  3. Corruption in the computer memory or memory in computer is bad.
  4. Other serious file corruption issue.
  5. Other hardware confliction or issue.
Aug 12, 2010 | Computers & Internet
Acer Desktop Veritron M460 will not load Windows XP or Vista!
This problem may occur if the Ntfs.sys file is missing or becomes corrupted when you convert your hard disk to NTFS To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, anddrive is the drive where you installed Windows XP.
  8. Restart the computer.I hope this helps.The other thing I can think of is maybe your harddrive needs a raid driver.If this is a sata drive and an old version of you os,the sata driver may not be already on the disk and you will have to insert one.Let me know if the first solution works,if not we can try the raid driver.
Apr 08, 2010 | Acer Veriton M460 Micro Tower Core 2 DUO...
Stop:0X00000024 (0x00190203, 0X86f02b00, 0XC0000102, 0x00000000)
A problem occurred within NTFS.SYS, the driver file that allows the system to read and write to NTFS file system drives. There may be a physical problem with the disk, or an Interrupt Request Packet (IRP) may be corrupted. Other common causes include heavy hard drive fragmentation, heavy file I/O, problems with some types of drive-mirroring software, or some antivirus software. I suggest running ChkDsk or ScanDisk as a first step; then disable all file system filters such as virus scanners, firewall software, or backup utilities. Check the file properties of NTFS.SYS to ensure it matches the current OS or SP version. Update all disk, tape backup, CD-ROM, or removable device drivers to the most current versions.
Feb 10, 2010 | Dell Computers & Internet
I am having trouble running setup on my desktop
Aug 28, 2009 | Computers & Internet
Hard drive backup
This seems to be a good article on ASR backup and how to eliminate your error message.
See Link
Dec 16, 2007 | Dell Latitude D600 Notebook
System32.ntfs is missing and corrupt
Boot into recovery console, and at the c:\windows prompt type: cd system32 cd drivers ren ntfs.sys ntfs.old If the ntfs.sys file is there and corrupt this will rename it. If it is not there, then it was missing. At the prompt type: copy e:\i386\ntfs.sys c:\windows\system32\drivers\ntfs.sys good luck
Mar 19, 2006 | Apple Power Supply 344 Watt PowerMac G4...
Computers & Internet Logo
71 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
