Question about Simplehuman The Furniture Store Pull Out Trash Can SHN1022
The slide out won't attach and it keeps sliding back out
    Problem Solver:
  • 13 Answers
Where the trash can / machine is, when installing it, was it put in level or on a slant, could be an easy fix if you take it out and try put it back in with an upward position, So when you go to the trash pullout machine, you will have to give it a little pull.
Posted on Oct 17, 2013
  • Rhonda Harris
    Rhonda Harris Oct 17, 2013
    I can check. When it was first installed, you would hear a little "click" when it attached when being pushed in. There is no longer any click, and it rolls back out and opens the cabinet door
How do lawn water slides generate water in order to allow the sliding?
Lawn water slides are generally attached to a water hose that will keep reversing water inside the slide and allow the slipping and sliding effect.
Sep 22, 2013 | Toys
I need to remove the wiper arms from my 2001 dodge ram truck
There is a small "lever or slide" for a lack of a good name at the moment . It is located at the base of the post where the arm is attached . It has a small lip on it that is what you use to slide it out , allowing the arm to slide off the post. It works as a" keeper" that is pushed back in to keep the arm attached when the arm is slid back onto the post .
Oct 03, 2012 | 2001 Dodge Ram 1500 Truck 2WD
Have a 28CC Husqvarna 2 stroke engine. Used it once, now the attachments won't slide far enough in to connect to the drive shaft and
Sounds like the upper drive shaft connected to the trimmer housing has slid down. Try holding the unit gas tank down, and turn the inner shaft until it drops back down into the unit, then attach the desired tool.
Jun 28, 2012 | Husqvarna 28cc Gas Line Trimmer
My smilebox slide show won't record.
My creations preview great but when I press the save to DVD nothing happens, I am not saying is a smilebox problem, but It used to work just fine. I am just wanting to know what to do because I just wasted 40 bucks if I cannot burn it
Jun 21, 2012 | smilebox.com
Paper pro one finger stapler
Chesspro5000 is right. You must open the stapler, pull out the slide, but instead of loading the staples directly on to the slide, you want to turn the stapler upside down and place the staples, face up, directly into the front of the stapler. Then, when you push the slide back in, it will glide directly across the staples and properly attach, rather than having to manually having to attach the staples to the slide yourself. Then close it back up and you should be good to go!!
Good luck!!
-Kelly
(Sorry for the repeat comment and any redundancy in my own message..!!)
Jun 04, 2012 | Tools & Hardware - Others
Slide tray won't turn and accept slide --the arm moves up and down but that is about all.
Sounds to me like one of the return springs has either stretched out or fallen off. There is no easy way to diagnose this.... takes hands on from an experienced tech. The Slide Lift Lever has to come up high enough to put the slide back into the tray, plus give enough clearance for the tray to rotate. I sure hope this helps. Jim
May 08, 2012 | Kodak Carousel 4400 Slide Projector
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't work...it says slide to unlock...and it won't slide...but the top that says slide to turn off...
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Jul 21, 2011 | Apple iPhone Smartphone
How to replace front discs and pads
Front brakes are very simple to do:
  • Pull off the front tires.
  • Remove the brake pads by removing the slide pin bolts where the piston assembly attaches to the caliper mounting bracket. The slide pin bolts are usually a 12 or 14mm bolt. Once the piston assembly is free slide the old brake pads out.
  • Compress the piston back into the caliper by using a large pair of channel lock pliers or a c-clamp. If you don't do this, you won't be able to get the new pads on.
  • Before you put the new pads on, replace the rotor.
  • Remove the two bolts for the caliper mounting bracket. They are in the back and are bigger than the slide pin bolts. Usually a 17 or 19mm bolt.
  • Pull off the caliper mounting bracket.
  • At this point the old rotor should slide right off. If it doesn't slide right off, look for a screw in the center of the rotor, some cars will have a screw there to hold the rotor on. If there's no screw and it still won't come off, try tapping it with a hammer. If you're replacing the rotor, don't be shy.
  • Put the new rotor on. Make sure to clean off any grease with brake cleaner that may be on the braking surface from packaging.
  • Put the caliper mounting bracket back on.
  • Put the new brake pads on. Make sure to use some anti-squeal grease on the back of the pads.
  • Put the caliper assembly back on with the slide pins. Grease up the slide pins as well.
  • Put the wheels back on.
  • Make sure to pump your brakes 10 - 15 times before you drive off. Because you compressed the piston back into the caliper, the piston will not be contacting the brake pads unless you pump the brakes.
Good Luck!
~Brandon
May 27, 2011 | 2002 Mitsubishi Lancer
Trimmer runs fine but attachments won't turn
I had the same problem. it is the clamp that your attachments go into. mine slide down a bit and the inside cables didn't engage. loosen the bolt on top and slide it back up. then secure bold again. if it keeps happening it is only a $6 or $7 dollar part.
Apr 16, 2011 | Craftsman Convertible 25cc. Gas Line...
What do you do with the extra rectangular slide
They're just there to keep the loose strap ends tidy. Slide them to where needed and thread the loose ends through them.
Mar 12, 2010 | Nikon D70s Digital Camera
Simplehuman The Furniture Store Pull Out Trash Can SHN1022 Logo
459 people viewed this question
Top Simplehuman Home Experts
john h
Tom Chichester
Are you a Simplehuman Home Expert? Answer questions, earn points and help others
