Question about HP Officejet H470 InkJet Printer
Makes screeching noise
Hello, The noise sounds like it needs to be oiled. Can this be fixed? Does it mean the printer is going to die? Thank you Nancy
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
No, it can be because of dust or might be need some oil as well. it can be fixed, just clean the printer.
Posted on Oct 17, 2013
2 Suggested Answers
  • 4 Answers
SOURCE: hp laserjet makes a continuous screeching noise when plugged in and will not print.
I have an identical situation. I have isolated the source of the loud screech to the (laser scanner assembly) p/n RGO-1041. The unit is located underneath the top cover, where the printed paper rests after it is ejected. I had to remove the right and left side covers, then remove the three screws holding down the top cover. There are two screws up front and one to the rear, it then lifts straight up. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps. Sorry, I accidentally posted this in problem section.
Posted on Apr 04, 2008
My jeep recently started to make a screeching noise when i turn it on. And when I reach a stop light it will shut off and not turn back on when I turn the key. It just makes a clicking noise. Please help!
Screeching noises usually mean a bearing is seized or about to seize. The fact it stalls and won't start indicates its more likely an oil pressure issue, since many car computers will shut the engine down to protect it from damage, if a low or no oil pressure condition is detected. You need to take it in ASAP and have it checked so any damage is kept to a minimum.
Mar 24, 2015 | Jeep Cars & Trucks
What can be done to fix my fi-6670?
You may need to lubricate the moving parts. I had a printer that was playing up like this and the bars that the print head moved on needed a tissue with a small quantity of machine oil to be rubbed on the bar to allow the print head to move freely. If all the scanners are the same age the lubrication they had may have worn off.
Apr 29, 2014 | Fujitsu Fi 6670 - Document Scanner -...
Wipers stopped working, car screeching, oil issues
the smell could be oil leaking on to the exhaust from the rocker covers.(common problem in Subaru because of the side mounted pistons. Engine stop oil leak might fix other wise will have to get tappet cover seals replaced as they crack over time from the heat) easy enough fix. a tell tale sign is signs of engine oil stains or signs of oil dripping on to the exhaust(can locate by looking under the front of the car at the bottom of the engine itself) and this is probably the cause of the engine knock due to low oil.it will continue to leak till the problem is fixed
Mar 29, 2014 | 1996 Subaru Legacy
My wife drove the mini van when it was low or almost out of oil. now the engine makes a loud knocking sound.......is the engine blown or is there a possible fix, to save the engine?
Knocking means you're still low on oil. Try have an oil and filter change. If your engine is blown, you won't hear or feel it cause it's seized. A dying engine from oil starvation would make screeching metal to metal noise. Yours sounds more like a stuck cam follower from oil starvation.
Jun 15, 2010 | 1998 Chrysler Town & Country
When I print with my bother 1450 hl laser printer, the printer ma
Hello sir; Before we go further I suggest you replace a new cartridge see what happen.
May 18, 2009 | Brother HL 1450 Laser Printer
Screeching noise
right click on the speaker icon in your taskbar, select Open Volume Control. If you do not see the Microphone control select options>properties and select it from the list of check boxes. Press OK. Check the mute box for your microphone.
Jan 04, 2008 | Lenovo ThinkPad X60 Tablet PC
HP Officejet H470 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
