Question about Singer 4423 Sewing Machine
I need the plastic plate for the on and off switch
  • Singer Master
  • 7,365 Answers
You'll have to contact a singer dealer for one or check on ebay
Posted on Oct 17, 2013
Where is the feed dog switch on the singer athena 2009 sewing machine
I'm not able to find a reference to a feed dog switch for your machine.
Singer Athena 2000 Instructions Manual Page 9
Could possibly be accomplished using a special plate? The instructions do refer to a darning foot, so the machine should be able to deactivate the feed dogs.
Nov 30, 2017 | Singer Sewing Machines
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
How do i drop the feed dog on singer 7463 confidence so i can free motion sew?
You cannot drop the Feed Dogs on a 7463 Singer. It should have come with a small black plastic shied that will slide over the Feed Dogs and clip into the two holes in the face plate to cover them completely. If you've lost that dark plastic plate, you can also tape an index card over them, or a piece of thin plastic (like template sheets) to get the job done.
May 20, 2012 | Singer Confidence 7463 Computerized Sewing...
I have a Pfaff 1471 which changes programs mid sewing after I have been sewing for a while, or if I leave it on when I am not sewing. The only way I have found to get back to the sewing mod that I need...
It's possible that the base plate, which has your power supply in it, is going out. Sometimes needles have been found inside the base plate from sewers putting pins on the top of the machine, and they fall inside. You might just loosen the 4 straight slot screws on the bottom of the machine, seperate the base plate from the machine to check for any pins or needles inside. Lay the machine on it's back to do this and DON'T forget to unplug it. If you choose to disconnect all the connection cables, be careful when you pry the tab to pull off each cable, cause of the heat created by the base plate the plastic tabs are brittle and they do break.
Apr 27, 2011 | PfaFF Sewing Machines
I have an Elna 6003Q sewing machine. My light bulb went out and I need to replace it. How do you get it out and replace it?
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Sep 27, 2010 | Elna 2007 Mechanical Sewing Machine
I have model 4795. When I received it in the mail
If I were you I would send the whole machine back for replacement
Mar 19, 2010 | Sewing Machines
Can the feed dogs be lowered? And need a manual....
Manuals will be difficult to find because the companies limit themsleves to the amount of spares they make, open the slide plate and see if there is a drop feed lever, if not you may have raised plates instead.
Mar 06, 2010 | Janome 8080 Computerized Sewing Machine
I need a needle plate spacer for my BMP6!
Call Bill Stone at Sarah Howard Stone's
The number is 334-262-7154
Oct 27, 2008 | Baby Lock Ellure
Singer 4423 Sewing Machine Logo
14 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
