Question about Lynx L-3X Compact Scooter
I want to install low voltage (12 volt DC) lights on my Lynx 3 scootor and would like to know if I could tap into a line on the top of the Tiller.
No run wire from one battery
Posted on Oct 19, 2013
Fault finding
Power is going to the motherboard, and you know this by assuming?
An assumption would be you see the Power Supply fan spin, LED lights light up, and maybe computer case fans spin.
Not an assumption, and you would have tested the 3 main voltage power rails, coming out of the Power Supply.
The Power Supply in your computer is an SMPS.
Switched-Mode Power Supply. (Also is known as the short abbreviation - PSU. Power Supply Unit)
http://en.wikipedia.org/wiki/Switched-mode_power_supply
The Power Supply in your computer is a Converter.
It converts HIGH AC voltage into 3 LOW DC voltages.
[Depending on country,
USA = 120 Volts AC. UK = 240 Volts AC. Japan is 100 Volts AC, but may depend on area. Australia = 240 Volts AC. India = 240 Volts AC. HOWEVER, do not write the above in stone. I may have made an error ]
The 3 low main DC Voltages coming out of the Power Supply is;
A) 3.3 Volts DC
B) 5 Volts DC
C) 12 Volts DC
Orange wires carry 3.3 Volts DC
Red wires carry 5 Volts DC
Yellow wires carry 12 Volts DC
ALL Black wires are Ground wires. They can also be called Negative wires.
This is a DC circuit now. There is a Positive, and a Negative.
Orange, Red, and Yellow wires are power wires, and also Positive wires.
The first part of your diagnosis will be to test those 3 main voltage power rails.
[Digressing;
Using an example;
There are many Red wires coming out of the Power Supply.
These are 5 Volt wires. They are Connected TO, the 5 Volt power rail in the Power Supply.
ALL 5 Volt wires end in one place, in the Power Supply.
The 5 Volt power rail.
When you test just ONE red wire, you are testing the entire 5 Volt power rail coming from the Power Supply.
This also goes for the Orange wires, and Yellow wires ]
With the Red 5 Volt wires, and Yellow 12 Volt wires, you could just use a 4-pin Peripheral power cable to check them,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Multimeter set to DC Voltage, the red (Positive) probe lead of the multimeter; touches the female metal terminal connector, for the Red wire.
http://www.mcmelectronics.com/product/28-9420&utm_medium=Affiliate&ref=cj&utm_campaign=CommissionJunction&utm_source=CommissionJunction?t=2&utm_expid=8634549-14
The black (Negative) probe lead of the multimeter, touches a female metal terminal connector, that goes to a Black wire.
You should be reading 5 Volts DC.
Same thing for the Yellow 12 Volt wire.
With an Orange 3.3 Volt wire, this changes.
A straightened out paperclip is inserted, down into the BACK of the ATX main power cable's connector; AND into a socket hole with an Orange wire in it.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The straightened out paperclip, slides down into the socket hole, with the Orange wire in it.
Slides down into the socket hole, RIGHT NEXT TO the orange insulation of the wire, and MUST go down far enough; to Touch that female metal terminal connector.
EVERY wire going down into the ATX main power cable's connector, ends in a female metal terminal connector.
Same thing is down with a socket hole that has a Black wire in it.
ALL Black wires are Ground wires. (Negative)
You can choose ANY socket hole that has a Black wire in it.
Now touch the two probe leads of the multimeter, to their respective straightened out paperclips.
Red (Positive) probe lead of multimeter, to straightened out paperclip in Orange wire socket hole.
Black (Negative) probe lead of multimeter, to straightened out paperclip in Back wire socket hole.
You should be reading 3.3 Volts DC.
(Or if your multimeter kit has special probe lead, that would take the place of a straightened out paperclip, of course use it instead)
Know this;
A) If ALL of the LED's ('lights') were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical CPU (Processor) can use 51 to 130 Watts of power.
Just depends on what Processor (CPU) it is.
This is why a Power Supply with a weak voltage power rail, will not have enough power to turn the Processor ON, but will have enough power to light those simpy LED's, and spin fans.
[LED - Light Emitting Diode ]
Regards,
joecoolvette
May 11, 2013 | Dell Computers & Internet
Hp computer tower will not go on
Would that be an LED (Light Emitting Diode), blinking on the back of the Power Supply?
If so, instead of being an LED that indicates the Power Supply has power to it, it has now turned into a diagnostic LED (Light), and is telling you the Power Supply is bad.
Do you have an economical multimeter, so I can guide you in testing the 3 low DC Voltages; that come out of the Power Supply?
An economical multimeter can be purchased for as little as $5 to $12.
I have seen them on checkout aisle racks, in major discount stores.
The dangerous high AC voltage, is kept contained within the metal case of the Power Supply.
(100 to 240 Volts depending on what country you are in)
The Power Supply is a Converter.
It converts the high AC voltage into 3 low DC Voltages;
3.3 Volts, 5 Volts, and 12 Volts.
In comparison two D cell flashlight batteries produce 3 Volts DC.
OR;
Use a KNOWN to be good, Compatible power supply; for a temporary test unit.
{"Honey, I'm going to borrow the Power Supply out of your computer.
I'll put it back when I'm done."
"What? I'll be sleeping on the couch? K"} (Lol!)
Also, is the inside of the computer dirty?
(Computer Unplugged from power, Anti-Static Procedures FOLLOWED)
Let's start here......
Also, what is the Product Number?
Back of computer tower, white Service Tag.
P/N = Product Number
Post back in a Comment.
Regards,
joecoolvette
Apr 09, 2013 | HP Pavilion Computers & Internet
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
Have you used the LED lights 12 Volt Led Light Bulbs are high energy saving, energy efficient and are small in size. They offer a brighter light than any incandescent bulb and have a low replacement and...
Hello There,
If you plan to have LED lights in your household the easyest thing is to buy the ones, they are made for line voltage (120 V). You have choices for bulb like shape or tubes. The tubes are available for direct replacement (using the existing ballast) ot the line voltage ones (the fixture's wiring should be modified and the ballast needs to be removed). The power saving is constant, by the time passing by you are saving.
Hopefully, this will help you. If you have more specific question, please let me know.
Jul 29, 2017 | Laser Vehicle Parts & Accessories
I have a dell computer. when i turn on the tower and monitor i get just a black screen on the monitor. i have pushed a few buttons on the bottom of the screen and it just says power save mode please use...
No, it's the Power Supply.
Power Supply has a weak voltage power rail.
The monitor goes to Power Saver mode because it is not receiving a video signal. (No Signal)
This is because the computer is not working.
Dell Support > Dimension 4700 desktop computer > Service Manual,
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Click on the heading - Advanced Troubleshooting
Is the Power On LED light blinking Amber? (Yellow)
Regards,
joecoolvette
{You can also test the power coming out of the Power Supply.
Switched-Mode Power Supply,
It converts the AC electricity from your home, or business, into DC electricity.
There are three main voltages produced;
A) 3.3 Volts (3 point 3)
B) 5 Volts
C) 12 Volts
All are DC voltage
Two D cell flashlight batteries produce 3 Volts DC.
(In case you are worried about being shocked.
The 'bad' electricity is contained inside the Power Supply's case)
If you do not have a multimeter, an economical unit can be purchased for around $8 to $12. A LOT of stores carry them. An auto parts store is one example.
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
ALL 3.3 Volt wires end at the same 3.3 Volt power rail in the Power Supply.
Same with 5 Volt wires, and 12 Volt wires.
You can test ANY Orange wire, or any Red wire, or any Yellow wire.
ANY Black wire you see is a Ground wire.
The red probe lead of the multimeter is the Positive lead. The black probe lead is the Negative lead.
The Positive probe lead is touched to a positive wire.
Orange, Red, or Yellow.
The Negative probe lead is touched to ANY black wire. ALL black wires are a Ground wire.
The function knob on the multimeter is set to DC voltage. (Dotted line over a solid line, with a dotted line under the solid line. The curved S line over a solid line is for AC voltage. This = No)
If there are different scale settings, set the function knob to 0-50 Volts. (DC)
Aug 24, 2011 | Dell Dimension 4700 PC Desktop
The fan control in the dashboard no longer turns the fan on at all. For a while, it would work intermittently, but now it's just dead. what is the best place to start troubleshooting this? thanks!
FIrst I would suggest checking the heater fuse. If it is OK, the nexxt thing I would do would to be to tap on the side of the blower motor with a hammer. If the brushes are stuck, some light tapping may loosen the brushes from the armature. If that does not work, remove the wiring connector from the blower motor, and check for voltage. Low should be 3 volts DC, low medium is 6 VDC, High medium is 9 VDC, and high is 12 VDC. If you have no voltage, and the fuse is good, you need a switch.
Oct 27, 2009 | 1997 Toyota Corolla
Mitsubishi 62 inch microdisplay hdtv w/screen w/zy
I have a list of problems common to this series here:
Cause #1
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for
12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check
for an open F9A09 on the Power PCB, if it is open replace F9A09 part #
283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out)
Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if
low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the
Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three
times and then the unit shuts down with a red lamp LED (lamp error). Replace the
Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch
to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light
Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low)
after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB
(ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-
volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light
I would start with #3, checking the 5 volt line and replacing the listed capacitors if needed.
Please be sure to rate this solution. Thanks!
Nov 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Wd52525 Ballast
Good Day, monkbuist;
TRY THIS:
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH. back.gif
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
New Lamp turning off after 5 seconds
Apr 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Correct voltage for lamp connection?
(Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 .
Oct 06, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Lynx L-3X Compact Scooter Logo
35 people viewed this question
Top Lynx Health & Beauty Experts
Vernon Taylor
Robin Hill
Robin Hill
Andrew Taylor
Andrew Taylor
Are you a Lynx Health and Beauty Expert? Answer questions, earn points and help others
