Question about Kenmore Ovens
Remove stains Hi. I clean the oven with Sos pads. Ithought i rinse it properly the next day i did an oven clean. AFter the cycle the oven still has soap marks in it. How will i remove it.
3 Suggested Answers
SOURCE: how to remove smoke stain ?
I just cleaned ours yellow stain using a metal/chrome cleaner, a "magic eraser", and a lot of elbow grease. It still has a yellowish tint but the cleaning made a BIG difference. I hope it works for you!
Posted on Jul 25, 2009
  • 827 Answers
SOURCE: There is always a yellowish staining on the top
the yellowish "staining" is a result of a bad seal. Since it is heat changing the color of the surface, you would probably have to do some damage to remove the discoloration, either like a soft abrasive scrub or other, bleach will not fix that.
Sounds like the cleaning cycle could be too long or otherwise too hot for too long? Perhaps a wipe down with a damp cloth to the interior of the oven prior to a self clean to remove any loose material may help.. Also if there are any other vents for this oven (say under one of the burners of the stove top) make sure they are kept free and clear of any blockage of air flow..
Best regards
Ck
Posted on Mar 12, 2011
How can I clean the inside glass of my Belling Format oven?
I have used SOS pads to clean glass with tough stains on it.
Dec 14, 2016 | Belling Ovens
How do I clean the lower oven for model rbd245
If you don't have a self cleaning oven, then use an SOS pad to remove any baked on stuff. You may want to scrape the heavy stuff first so that the SOS pad will be more effective.
Jan 26, 2015 | Whirlpool RBD305PD Electric Double Oven
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
How to clean my jen air built in oven
For basic cleaning, use a non-abrasive cleanser or detergent and water. Clean the oven frame, oven door outside of the gasket and the gap in the gasket. (Don't clean the gasket.) With a damp sponge (with detergent if needed), wipe up any spills in the oven. (Sugary or acidic spillovers could damage the porcelain.) Wipe up any grease that spilled in the oven. Wipe the control panel with a damp cloth then dry. Clean the oven door with detergent and water. Clean the window or glass with detergent and water or glass cleaner. Use care to keep the water from seeping behind the window.
Next if you want to do a self-cleaning cycle. Remove the oven racks, the broiler pan and any other pans or items that are in the oven. Close the oven door. Press the Clean pad and then press Autoset(0) button to get the length of time to run the cleaning cycle. Press 2 or 4 to shorten or lengthen the cleaning cycle. After 5 seconds the door will lock and the cleaning cycle will begin. The door will remain locked until after the oven cools down (at least an hour after the cycle ends). Wipe up any white ash after the oven door unlocks. If you want the cleaning cycle to be delayed, press the Stop pad within 5 seconds of setting the length of the cleaning cycle. Use the number pads to set the time that you want the oven to end the cleaning cycle. (Make sure that it is later in the day with sufficient time to run the cleaning cycle.)
Most Jenn-Air manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . The direct link to the manual for the JJW8530CAA is http://www.kitchenaid.ca/assets/pdfs/literature/JJW8527AAB.pdf .
I hope this helps.
Sep 11, 2011 | Jenn-Air JJW8530C Expressions Collection...
There is always a yellowish staining on the top part of the oven door, door handle and vents after self cleaning. I've tried bleach, sos, Mr. Clean Magic pads and it barely removes it. What do you...
Best regards
Ck
Mar 12, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Do I remove the racks before self cleaning my Viking oven? Will it dull the shiny finish? How do I clean them if I take them out?
It is a matter of personal choice to whether you remove the rack`s or not, no harm will come to you from not removing them but...If they are chrome finished they will become very dull and look like bbq grills over time and in extreme cases, warp and consequently not fit well.
If they are finished with enamel to match the oven liner, don`t worry, they are designed to be left in place, even during self clean cycles.
As for how you can clean them. You can do this by removing them and with a suitable work space (a bath tub or laundry tub works great) with regular oven cleaner`s, (preferably environmentally friendly...check your local by-laws) or other household cleaners with the assistance of a scrub pad and elbow grease. Be sure and rinse them thoroughly when finished with the cleaner`s.
Hope that help`s. If so, please take a second to rate the solution provided by me here at fixya. Thank you.
Good luck.
macmarkus :)
Dec 05, 2009 | Viking Ovens
If I DO NOT want to use the self cleaning feature is there any other safe way, including using soap and water, to clean the oven without ruining it? (I don't want to use the self cleaning feature)
  1. Oven door : Wash the door and window with soap and water and rinse with clear water. Use glass cleaner only if sprayed on a cloth first. Do not use abrasive pads, powdered cleaners, or steel wool on glass and enamel, or the surfaces will be scratched.
  2. surface burner : To absorb a spill when it is hot, pour salt on it and wipe it up when the oven has cooled. A mildly abrasive baking soda and water paste can be used in the oven, too.
  3. Racks:Remove oven racks and clean them in warm, soapy water. Stubborn messes can be cleaned by using mild abrasive cleansers or a soap filled scouring pad. Rinse and dry the racks before returning them to the oven.
  4. Metal trim:Metal trim can be cleaned with glass cleaners or mild cleansers, soap and water. Abrasives or cleaners made for oven interiors should not be used.
Thanks
Smith.
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
