Follow this steps and fix it. God bless you
Check
power problems if the console on the elliptical machine does not light up. Make
sure that the plug for the machine is secure in the outlet. If it is plugged
in, ensure that the outlet is receiving power. Check the breaker to make sure
it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical
machine. Because different adapters are able to handle differing amounts of
energy, the wrong adapter will not transfer electricity like it should. If the
adapter is pinched or damaged, this could also alter its effectiveness.
Make
sure the correct adapter is being used if the resistance settings seem to be
too hard or too easy. If the correct adapter is being used, reset the machine.
To reset the machine, either switch the "On/Off" button or unplug the
machine from the wall. Doing this will allow the device to reset itself to the
default resistance. Turn on or plug the device back into the wall and retry all
of the levels of resistance.
Do
not be concerned if you see small particles left on the guide rails. Over time,
the roller wheels gradually wear down. When this occurs, they leave residue on
the rails. Because this is considered to be normal wear, all you need to do to
fix the problem is wipe the rails off with a damp cloth.
Minimize
the risk of receiving erratic readouts on the monitors by avoiding outside
interference. For example, gripping the heart rate handlebars too tightly can
affect the monitor. Similarly, the heart rate grips can be rendered less
effective when there is too much vibration. Consider not holding these monitors
throughout the workout to minimize vibration. The readouts also can be affected
by jewelry. To minimize errors, take off rings and other jewelry before working
out on an elliptical machine.
SOURCE: I have a Sole F63
Test the flexible cable from keypanel vs display board and tigh the connector from display board vs main controll motor board. Test the relais if there are. Test for open and close, and clean the contact with spray for clean contact. Watch the videos. Finally the display board can be faulty b) main motor board too faulty.
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=relatedgood luck , sincerely God bless you.
E.CUADRA
MANAGUA, NICARAGUA
