My speed queen washer is stuck in the rinse cycle and won't do passed that cycle. Any help would be appreciated.
  • 183 Answers
SOURCE: Amana Speed Queen (LWS34AW)
Probable gear box fault Regards Engineer
Posted on Jul 30, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series washer
The switch you're talking about is called a "lid switch". It can be by-passed, but it is there for a reason. The switch is used to prevent the tub from spinning or agitating with the lid open. This is a safety measure to prevent personal injury. You mentioned that the switch was "missing". It may have simply come loose and fallen inside the washer between the case and tub. More than likely, it is hanging by a ground wire and a plug. If you can retrieve the switch and screw it back in place on the rim of the wash tub opening, you may actually fix your problem. However, if the switch is broken, you need to replace it. Here's how:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
PS To answer your initial question about by-passing the switch, when you remove the console and disconnect the lid switch, you can take the connector that is MOUNTED ON THE WASHER TOP and remove it by pressing the release tabs and pulling it from under the tub rim. This is the connector plug that runs to the lid switch. Cut the plug from the switch, leaving a couple of inches of wire. Short the two black wires together, insulate the ends and cut the green wire flush. You now have made a by-pass plug. Simply plug it in to the connector that is RUNNING FROM THE TIMER and (voila!), you have a working washer. Keep in mind that now your washer will NOT stop when you open the lid. Use caution if you're going to operate your machine in this manner.
Now...if you're going to go this far, you should replace the switch. A new switch runs about $35 or less. Its an easy repair if you follow the directions. Keep the plug handy in the event that you run into this problem again and need to drain and spin the water out.
Good luck to you and let me know if you need any further assistance.
Posted on Feb 22, 2008
  • 156 Answers
SOURCE: Green grease? stains from my older Speed Queen washer.
your seals and gear case needs replaced
Posted on Feb 25, 2008
SOURCE: I also need the answer...
where is the lint trap located
Posted on Apr 07, 2008
SOURCE: Maytag A482 top load washer
water does not shut off. tub overflows.
Posted on Jan 08, 2010
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Rinse cycle doesnt work
Because the water from the wash is still inside it and has not drained. So you need a new drain pump!
Jan 19, 2014 | Speed Queen AWN432 Washer
Speed Queen Model RWM373W-3062, 7.2kg Washer made loud noises while washing kla kla kla. We tried to get repairman but nothing available locally for domestic only commercial repairs. Now machine has...
it's a reasonable assumption, that the transmission on the washer went, not too hard to replace, but first you have to drain it....and lay it , more than likely, on its back or side to get to the part , accessed through the bottom of the unit most likely
Jun 06, 2011 | Washing Machines
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
10 year old Speed Queen washer, spin cycle does not work
likely the lid switch has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Speed Queen AWS52NW Top Load Washer
The washer quits at rinse and spin dry cycle
I've had the same experience with my Speed Queen washer. Approached the accredited Speed Queen agents for assistance, when tech support was deployed to diagnose the problem.
In the end, I was told that the "timer" went bust. So the wash cycle seems to work 100%, but when it comes to rinse and spin the contacts on the timer don't make contact, and the motor waits in anticipation for it's next command, and that the high pitch noise heard.
Jul 04, 2009 | Speed Queen AWS52NW Top Load Washer
Washer is overfilling & leaking
Are you using front loader only detergent?(oversudsing) Overfilling is either a pressure switch, or pressure chamber is blocked(located toward underside of outer bowl approx 6 inches long) this is only in older machines with extensive cold washes.
May 23, 2009 | Speed Queen ATS90AWN Front Load Washer
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
