Question about AC Delco Fuel Pressure Regulator 1998 Oldsmobile Bravada Fuel Pressure Regulator AC Delco
Where is the fuel pressure regulator located on a 1998 Oldsmobile Bravada?
Fuel filter location olds bravada
he fuel filter is located along the driver side frame rail...
Sep 17, 2011 | 1998 Oldsmobile Bravada
How to fix fuel pump regurlator for a 1998 oldsmobile bravada
If you mean 'fuel pressure regulator,' these are not repairable but sealed and if failed, have to be replaced by new.
Aug 29, 2010 | Oldsmobile Bravada Cars & Trucks
1998 bravada not getting fuel to the throttle body, fuel pump is working fine. what else could it be?
If you have a throttle body, then you most likely have to injectors inside the throttle body. Check to make sure that they are funtioning correctly. You can check by using a voltometer and testing the injectors' lead wires for an electric signal, there should be one. Also, check to make sure your fuel filter is not completely stopped up, it happens. Also, sometimes the fuel pump can turn, but not put out enough pressure to start the car. There is also a fuel pressure regulator on many late model vehicles that can malfunction. I would check that as well.
Jan 14, 2010 | 1998 Oldsmobile Bravada
96 Oldsmobile Bravada 4.3 liter
The fuel pressure regulator is located under the intake plenum attached to the six in one fuel injector.They leak quite often causing hard start conditions.The injector is also known as a spider injector which will come with the regulator .
Aug 01, 2009 | 1996 Oldsmobile Bravada
Where is the fuel pressure regulator located onthe 96 olds Bravada 4.3 liter located ?
it is below the upper intake manifold assembly, you have to remove upper manifold for access...
Fuel pressure regulator
Regulator is under plastic intake plenum.
May 04, 2009 | 2000 Oldsmobile Bravada
Where is the fuel pressure regulator located at in a 94 bravada
My friend, I suggest you go by your local Auto Parts Store and purchase a Haynes Repair Manual on this vehicle. There are many sensors and electronic controls involved with this engine as I'm sure you already know. Any one of these can memic something that "it is not".
If your problem is the Pressure Regulator, it is located inside the "Tunnel Ram" intake manifold along with the multiport fuel injection system.
Now,,, before I went through the trouble and expense of going into the Intake Manifold, I would run the EMC in Diagnostic Mode and see if there are any codes present.
Jan 20, 2009 | 1992 Oldsmobile Bravada
Fuel Pump Regulator
They are either right on the fuel rail... and I do believe yours is . Or on the intake manifold.
Aug 22, 2008 | 1998 Oldsmobile Bravada
AC Delco Fuel Pressure Regulator 1998 Oldsmobile Bravada Fuel Pressure Regulator AC Delco Logo
Top AC Delco Fuel Pressure Regulator Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an AC Delco Fuel Pressure Regulator Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
