Question about Plumbing
Price pfister faucet repair classic cupc
Water is squirting out hand sprayer, when water is turned on. like there is air in it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
Hand sprayers are often designed to aerate
Posted on Oct 20, 2013
  • 92 Answers
SOURCE: New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
Posted on May 04, 2009
  • 4 Answers
SOURCE: kit. sprayer/hose
watch this http://www.pricepfister.com/about/diverter.aspx
Posted on Jul 02, 2009
  • 23 Answers
SOURCE: moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Posted on Jul 20, 2009
  • 39 Answers
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
Posted on Aug 04, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
Garden hand pump sprayer not presssurising
There is probably a leak somewhere in the hosing or gasket. As you try to pump it up, take some soapy water and pour it around sealed areas of the sprayer. Look for bubbles as the sprayer leaks air. Also check the nozzle of the sprayer for a clog. Rinse it thoroughly with hot water until it has cleared any blockage.
Feb 22, 2014 | WD-40 Foaming Bike Wash 1L With Sprayer
The 3 sprayers in my Jenn Air dishwasher do not spin.
repairs should be preformed by an authorized service person. the flat tube in the rear is a manifold that allows water to flow from the main motor assembly. if there isn't enough or any water flowing to the manifold then the manifold is disconnected from the main motor or the main motor is not pumping efficiently. replace the main pump assembly or reconnect the manifold to the pump if dis connected.
Jun 04, 2017 | Jenn-Air 24 in. JDB1250AWS Stainless Steel...
Drain water from air compressor
Place your hand under it and it will sting you quite nicely. But it is normal.
May 28, 2012 | Campbell Hausfeld AIRLESS PAINT SPRAYER...
Reservoir is full of fluid, hear pump noise when button is pushed, but no squirt on window. Front winshield washers and wipers work fine, as does rear wiper.
Park the vehicle in a dry area, try pressing the washer, open bonnet and have a look to see if there is any water on the ground or in engine bay, if there is then one of the hoses that go to the washer nozzles have broken or come off, simply replace, if there is no sign of water, get yourself a fine pin and clear the nozzle with it (where the water comes out from), if you can get behind the nozzle you can also blow it out with compressed air, usually this happens after polishing the vehicle.
Feb 14, 2011 | Dodge Magnum Cars & Trucks
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
Bissell quicksteamer 1770
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix. My model is different than yours, but many models are similar.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Feb 22, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
I have a Bissell model 1694 It is not pumping water
Jan 20, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Proheat 8910 does not spray water onto carpet.
Jan 14, 2009 | Bissell 8910 ProHeat Clear View Upright...
Windsheild Wiper Fluid will not squirt on windshield
I just fixed the wiper jets on my car this evening - you may have a similar problem of having hardened gunk (deposits) blocking the sprayer. Removing them is relatively easy: Open your hood and note that there is most likely a vibration-dampening cloth/fabric secured to the inside of the hood. You will need to remove the round discs that are holding this in place (most likely Christmas tree plugs - there are around 8 or so). Once removed, you will have access to the back of the sprayers. Some are held in with a nut, others are clipped in to place. You can remove the sprayers and try cleaning them or you can replace them with new ones (relatively cheap and guaranteed clog-free).
Jan 04, 2009 | 1997 Nissan Pathfinder
Our bissell proheat carpet cleaner model 3750-T will not **** the water and cleaner through. Is there a schemetic available for free on this or a similar model
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix. My Bissell is a different model than yours, but many are similar.
Dec 22, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Plumbing Logo
126 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
