Question about Garden
Chain saw chain won't move when engines on - Garden
    Sergeant:
  • 458 Answers
Do you know if your saw has a safety device called a chain brake? If it does you move the lever just in front of the front hand grip towards the back of the saw to release it.
Posted on Jun 17, 2014
Chainsaw chain sprocket won,t turn
this seems to be a chain brake that's applied , try turning off chain brake by pulling back on hand guard till a click is felt
some folks moving up from an older saw to a more modern saw are not so familiar with chain brakes and don't understand them and how they work
May 25, 2014 | Ryobi Factory Reconditioned 18" 40cc...
Chain won't move after chain replacement
Had this happen to mine when I was limbing stuff that was too small. I know better. There is probably a burr on one or more of the guide portion of the links where they run in the bar. This causes that link to be tight in the bar at this point. The chain probably hit something on the body of the saw when it flew off. Take the bar off the saw and run the chain through the groove in the bar. If you have any links with nicks, they will bind, causing the chain to stick and not run freely. Once you've identified the problem links you can remove the nicks using 120 grit paper backed up with a flat piece of steel so you only remove the high spots.
May 05, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Model 51 won't start. Was running fine and has never had a problem starting (owned since new, 14+ years). Chain slipped off. Fixed and then saw wouldn't start. Good bright spark &...
If you have a good spark, and there is fuel at the plug, the only things to stop it fireing up are a sheared flywheel key knocking the timeing out, or the engine has low compression due to wear or damaged piston and ring.
Sep 07, 2011 | Garden
I can't unlock the blade.
Do you mean the chain won't move, or you can't get the blade off? The chain brake must be off to allow the chain to move. The chain brake handle has a housing that engages a gear attached to the chain brake inside the cover where the blade is attached. The brake must be off to remove the cover (usually held on by two nuts). The blade tension screw should be loosened to allow the blade to be removed, then retightened when replacing the blade. Tightening it pushes the blade out from the saw, so if it is tight, you won't be able to remove the blade. Hope this helps.
Aug 27, 2011 | Garden
Chain won't move when motor running
Sounds like the chain brake is on, grab the hand guard and pull it firmly back to the top handle to release the brake.
Aug 17, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
My 18" Poulan Pro Wild
Sounds like your chain is to tight.Take the cover that is at right side of the saw motor off and loosen the two nuts a bit and look for a tension screw behind the bar and back it off,if the bar won't move loosen the two nuts that hold the bar on the saw.With the saw siting like you use it pull down on chain and get about 1/8 of an inch between the bar and chain.(use gloves)If the bar is blue by the chain groove You will need a new bar.Blue means the bar has over heated and lost its temper.The blue metal is brittle in other words.You should all so check the drive sprocket for wear.
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions. Thank you for choosing FixYa.com and good luck.
May 20, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
After a few months in storage, my saw will start, but the chain seems stuck - I can['t move it with my fingers, and when I gas up the engine, the chain doesn't move & the engine stalls. There's no...
Release the chain tension adjuster and push the bar inward to make sure it moves. This is an auto-set tension adjustment and should set itself so that the chain can be be moved by hand. The chain oil on the bar may have gelled enough to prevent chain movement. A spray of WD-40 around the chain perrimeter would probably loosen the chain as well. Hope this helps!
Aug 15, 2010 | Husqvarna 450 e-series 18" Chain Saw
Saw is running, but chain is not moving
If you rev the engine and the chain does not spin, either the chain is jammed, or is adjusted to tightly on the bar, or the centrifugal clutch is malfunctioning. With the engine off and leather gloves on, see if the chain will move on the bar, you should be able to move the chain 4 or 5 inches. If you can spin it, the clutch is probably bad. If its stuck, take the housing off over the clutch and make sure the chain is seated on the sprocket and not jammed to the side. Inspect the chain on the bar, there should some slight play in the chain tension. Look for any links that dont flex. This happens to be cause I overtighten the chain to the bar.
Dec 22, 2008 | Homelite Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
