Question about Rockford Fosgate Punch 801S Car Audio Amplifier
Hi, I was trying to replace my subs and during the process, the positive wire touched the negative wire and my amp turned off. I have the Punch 801s 2400 watt amp. Is there a way to reset it? I'm assuming the amp went into protection mode. Any help would be appreciated. Thank you
  • Rockford Fos... Master
  • 637 Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping. A thumbs up would be greatly appreciated if this answer is helpful to you. GOD BLESS YOU.
Hi, I was trying to replace my subs and during the - trying-replace-subs-during-peeu4x5nsxvd53n2rwetiqa4-3-0_0.jpg
Posted on Dec 19, 2014
    Problem Solver:
  • 19 Answers
If you didn't smell any thing you should be able to replace the fuse. It's cheap enough to find out.
Posted on Dec 03, 2013
3 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
Posted on Apr 23, 2009
UpfrontAudio
  • 47 Answers
SOURCE: Amp or something cutting out.
Power caps store power from the battery and they feed constant power to the amp so you dont get no drainage! this could be one reason..
have you bridged both subs and wat gauge wire are you using.
these amps can only handle one bridged sub at 4ohms and this amp is recommended that u use 8gauge or higher. if your running to subs i normally reccomend using 4 gauge power wire as you get more rms power feed to the amp
you can get a power cap or anyother accersory cheap online at my suppliers.. caraudiosecurity << click to enter >> hope this helps and please rate me :)
I have 2 10" Kicker Comp Subs
That amplifier is only rated at 150 watts at 4 ohms, or 300 watts at 2 ohms. Not a very strong amp to run 2 kicker comps. My guess is you have the subs wired wrong for your application. There are 2 types of subs, one is a dual 4 ohm, and one is a dual 2 ohm. Most people bridge these coils together and that cuts your ohms in half. For example. Lets say you have the 10cvr104 subs. Thats the dual 4 ohm sub. You wire the coils together in parallel, now its a 2 ohm sub. You have 2 of these subs running off of your amp, if they are hooked up in parallel, now you have a 1 ohm load, out of the amplifiers normal operation. Your amplifiers internals heat up really quick and there is a thermal overload, putting your amplifier into circuit protection mode. My suggestion for wiring your subs is as follows: for each speaker, wire the coils together like this- positive coil1 to negative coil 2 and negative coil 1 to positive coil 2. That is called running in series, and doubles your ohm load. Next, we need to wire the speakers together properly to hook up to your amplifier. For this, since the coils are hooked together, you only need to use one set of terminals from each sub. And take the positive from sub 1 and hook it to positive of amp. Take negative sub 1 and hook it to positive of sub 2. Take negative of sub 2 and hook it to negative of amp.
Aug 30, 2012 | Rockford Fosgate Punch 301M Car Audio...
How to wire a dual 4 ohm speaker
if im not mistaken the speaker should have a +, - terminal on each side. route a wire from one positive to the other positive and then run another wire to the amp. on the negative terminal do the same, connect the negative to the negative then route a wire to the amp that way it hits a hell of a lot harder than your average sub
Jan 15, 2012 | Rockford Fosgate Punch HX2 RFD1210 Car...
I got a rockford fosgate 801s. and i cant find where the fuse is located.
Regards, Tony
May 22, 2011 | Rockford Fosgate Punch 801S Car Audio...
Why do i need to open my gain up to 3/4 to full turn inoder to achieve a loud bass?Im using punch 2400 amp and 2 12" kicker.
the amp may not be powerful or your setting on the cd player is not right try adjusting the cd player. turning the gain all the way up will damage your subs even go above halfway
Sep 19, 2010 | Rockford Fosgate Punch 801S Car Audio...
I need to wire up a rockford fosgate punch hx2 12" subwoofer to a 500 watt single channel amp and i need to know how to wire the dual voice coil properly ??
Wire it in a series. One wire from amp positive to one positive speaker terminal. One wire from amp negative to negative speaker terminal. This should leave one positive and one negative termianl on the sub. Use one additonal wire to connect these two, this wire should not be connected to anything else other than the two remaining terminals. This will allow you to have the music up louder with higher amp settings without having to worry about blowing the speaker as easily.
Jun 24, 2010 | Rockford Fosgate Punch HX2 RFD1212 Car...
How should i wire up a dual voice coil 12" sub? should one wire from the amp go on the positive of one voice coil and one on the negative of the other...? and then jump a wire from the other two empty...
That would be wiring it in a series. It would double your resistance (ohms) and lower the power (wattage) thats going to your sub. If your amps rms rating is the same as the subs rms rating then I would suggest that since it will protect your sub from blowing more than running a single wire through both positives and another one through both negatives. If your amps rms rating is less then I would suggest the other way. It will lower the resistance which will allow more power. All depends on the amp. hope this helps
Jun 24, 2010 | Rockford Fosgate Punch HX2 RFD1215 Car...
How do i hook them up to work for 2ohm's
Hello rcantu76,
If your CVR's are 2ohm (model Nr. 07CVR122), you connect the voice coils in series and then parallel both subs to the amp. If the subs are 4ohm (model Nr. 07CVR122), they cannot be wired to 2ohms. Your choices are 1ohm or 4ohms. According to Rockford-Fosgate's data on the P1000-1bd, it is stable at 1ohm.
To wire the 122's at 2ohms, you would connect the sub voice coils in series (jumper one positive to the other negative on each sub), and then connect the remaining positives and negatives to the amp.
To wire the 124's at 1ohm, you would connect all of the positives and all of the negatives together to the amp.
Hope this helps.
May 11, 2009 | Jl Audio 500/1 Car Audio Amplifier
Will my car handle a rockford fosgat 801s power load?
Hello dreww1005,
If your alternator and battery are in good condition, you probably don't need a capacitor. At maximum output, the 801S will need to draw a little over 30 amps at 12.8V. The specifications call for 8-gauge power and ground wiring and a 40A primary fuse. The Vibe's electrical system should be able to handle it OK.
Hope this helps.
May 08, 2009 | Rockford Fosgate Punch 801S Car Audio...
Amplifier loads
Hello ronnieyannon,
Hope this helps.
Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford Fosgate Punch 801S Car Audio Amplifier Logo
130 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
