Question about Kenmore Elite 45986 Front Load Washer
Kenmore 11046462501 weak motor wont spin with
Kenmore 11046462501 weak motor wont spin with clothes in it, but spins when empty, also has broken shocks
SOURCE: Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Posted on Feb 27, 2008
JOE LLAMA
  • 26 Answers
SOURCE: kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Posted on Apr 04, 2008
jsrock516
  • 5911 Answers
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
Posted on May 15, 2008
asish_shrm
  • 121 Answers
SOURCE: Kenmore 90 Series Washer
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Posted on Nov 12, 2008
  • 188 Answers
SOURCE: 80 series kenmore washing machine not spinning in spin cycle
You may either have a broken motor coupler (connects the motor to the transmission) or the clutch/brake assembly is slipping. To test the motor coupler start a cycle, if it fills and agitates, the coupler is ok.
You can check the clutch/brake by selecting the spin cycle, open the lid and press the lid switch down using a pen. When the motor starts check for either a very slow spin or give it a boost by pushing the inner drum clockwise and see if it picks up any speed. If it spins just a little, the clutch/ brake assembly is slipping and will need to be replaced.
Posted on Feb 19, 2009
Washers empties water but wont ring out clothes
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Transmission or clutch assembly not engaging due to going out or slipping.
Sep 28, 2014 | Maytag Neptune Washing Machines
Kenmore type 111, very weak spin
Clothes do not spin out good on NORMAL regular express, but do on casual.
Jun 24, 2009 | Kenmore 22422 Top Load Washer
Kenmore model 23832100 washer will not spin in rinse cycle
the motor it's self may be getting weak this happened to me.try running it through a small cycle with no cloths in it .holding the buton down under the with a small object so you can have the lid open to see exactly what's going on.if it seems too work like that.your probably talking new motor.
Jun 02, 2009 | Kenmore 22422 Top Load Washer
Washer washes and wont spin clothes in either the wash or rinse cycle
If you have little to no agitation (as well as spin), look for a broken motor coupling (connects motor to transmission).
If the motor coupling is ok, open the lid and select a spin cycle, insert a flat screwdriver or pen into the lid switch and try pushing the drum along in a clockwise direction. If it doesn't spin or spins slowly then the brake/clutch assembly is slipping and will need to be replaced.
Feb 25, 2009 | Kenmore 24032\24036 Top Load Washer
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 washing machine won't spin
No belts on that washer. You need a new clutch, the clutch cant grab the basket drive tight enough to spin. I will try to add a tutorial on it tomorrow. Look here for tutorial. www.shop.washermd.com Dave
Jan 05, 2009 | Kenmore 24902 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
48 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
