Question about Car Audio & Video
Car Speaker Biltema - Car Audio & Video
DOES WEB CAMERA BILTEMA 24-742 WORK WITH LINUX
Try it with MANJARO LINUX is likely the one that support it otherwise Opensuse, Fedora, or Mint
Sep 19, 2016 | Computers & Internet
2011 holden cruze radio wiring diagram
2011 Chevrolet Cruze Car Radio Wiring Guide
Car Radio Battery Constant 12V+ Wire: Red/Dark Green
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: Dark Blue
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 1? Tweeters
Car Audio Front Tweeter Depth: 1?
Car Audio Front Tweeter Location: 1?
Left Front Speaker Positive Wire (+): Dark Blue
Left Front Speaker Negative Wire (-): Brown/Dark Blue
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Yellow/Black
Car Audio Front Speakers Size: 6 1/2? Speakers
Car Audio Front Speakers Depth: 3 1/4?
Car Audio Front Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Dark Green
Left Rear Speaker Negative Wire (-): Dark Green/Black
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Dark Blue/Black
Car Audio Rear Speakers Size: 6 1/2? Speakers
Car Audio Rear Speakers Depth: 3?
Car Audio Rear Speakers Location: N/A
Car Subwoofer Speaker Positive Wire (+): N/A
Car Subwoofer Speaker Negative Wire (-): N/A
Car Subwoofer Speaker Size: N/A
Car Subwoofer Speaker Depth: N/A
Car Subwoofer Speaker Location: N/A
Jan 02, 2016 | Holden Cars & Trucks
2005 nissan pathfinder xe 8 speaker wiring COLOR
Check this for...
2005 Nissan Pathfinder with Bose Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Green/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: Green
Car Stereo Amp Trigger Wire: Green
Car Stereo Amplifier Location: Under the Driver Seat
Car Audio Front Speakers Size: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Negative Wire (-): Brown
Car Audio Rear Speakers Size: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
2005 Nissan Pathfinder Car Radio Wiring Diagram
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Brown
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Red
Left Rear Speaker Positive Wire (+): Green
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Orange
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | 2005 Nissan Pathfinder
WHAT ARE THE SPEAKER COLOR CODES
2000 Cadillac Deville Car Stereo Wiring Diagram, SPEAKERS ARE HILITED
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 29, 2011 | 2000 Cadillac DeVille
Radio wiring hook up
1996 Dodge Avenger Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/White
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: Orange/Brown
Car Stereo Dimmer Wire: Black/Green
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
1996 Dodge Avenger with Infinity Audio Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Illumination Wire: Green/Orange
Car Stereo Dimmer Wire: Green/Yellow
Car Stereo Amp Trigger Wire: White/Black
Car Stereo Amplifier Location: Mounted under the rear deck. Some models have a black plastic trim covering the factory amplifier.
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 15, 2010 | 1996 Dodge Avenger
I have 1995 volvo 940. how do you reset the service light
Buy a service light reset tool. try www.biltema.se and look up part no, 15-1389.
Mar 27, 2010 | 1995 Volvo 940
Trying to hook up a new stereo. Where can i find a wiring schematic for a 1994 toyota pickup?
Car Radio Constant 12V+ Wire: Blue/Yellow
Car Radio Ignition Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Stereo Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope this helps
Dec 10, 2009 | 1994 Toyota Pickup
How to remove the indash CD Player from my 1995 Suzuki Swift
In front of your stereo there are 2 very small holes on each side.
you have to buy a couple of these:
http://www.biltema.no/products/productimage.asp?iItemId=78544
Then you can just pull out the stereo. Good luck :)
Apr 09, 2009 | 1993 Suzuki Swift
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
