Question about Frigidaire FRT125GW (12 cu. ft.) Top Freezer Refrigerator
I have a Frigidaire model# FRT18HB5JW5, it is only a few years old. It has ran fine up til now. Freezer is fine but the temp in the refrigerator part is too warm. I turned the know all the way up but it doesn't seem to make a difference. If this is a matter of defrosting it, what method do you suggest?
  • patricia
    patricia Oct 19, 2013
    Thanks for everyones help, i had a repairman here yesterday. He told me it was the defrost timer. I am happy to have it fixed.
Master_Tech
  • 770 Answers
SOURCE: The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Posted on Feb 17, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
ryeisenman
  • 9 Answers
SOURCE: cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Posted on Dec 13, 2008
  • 71 Answers
SOURCE: refrigerator is too cold. Freezing milk and vegs.
sounds like the solenoid door is broke or stuck ,unless you are real handy , just tape up the air inlet in the refrigerator little by little until you get it right.
Posted on Dec 15, 2008
  • 111 Answers
SOURCE: Frigidaire refrigerator side-by-side freezer making loud noise
fan motor probably rubbing in something
Posted on Jun 19, 2009
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Our freezer just apparently stopped freezing, but the refrigerator still works. It's a Frigidaire Gallery just purchased a few months ago. Suggestions?
Hello, Thank You for using FixYa. I will be helping you today.All the cooling comes from the freezer side. So if the fresh food side is working then the freezer is only producing enough to allow the temps to be around 38 degrees. Do you notice any frost on the freezer back wall? Its possible its a defrost issue.Can you hear the fan Running in the freezer when the compressor is on? If these all seem fine then I would say you have a sealed system issue. Either a leak or bad compressor. Since its only a few months old call for factory service it should have a one year warranty on parts and labor.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a freezer top refrigerator in a rental unit of mine. It is only a few months old. My tenant said the freezer is working fine, but the fridge is not cold. He has tried putting the cold switch in...
Have him put a thermometer in a cup of water overnight and set the upper freezer
knob to the middle position and the temp control to midpoint. The refrigerator temp should
be between 34 and 38 degrees. You can get a thermometer at walmart or an appliance
parts store. If you continue to have the problem then change out the defrost termination
thermostat (this was a common failure in many of my frigidaire units). It is located in
behind the freezer back panel, it is clipped to a tube and has two wires coming to it.
Remember to unplug unit before servicing. The part is under 20 dollars usually.
The model number is located in the fresh food compartment on the left side. Hope this helps
Apr 25, 2011 | Frigidaire Refrigerators
Frididaire fridge mod.#FRT21IL5DBA 4 1/2 yrs old. In outside storage room of carport. Stopped running after stretch of low 20's temps. in winter of 2009 Unplugged it, checked coils. Plugged it in when...
Well it should be fine when it warms up, these are not designed to run in anything below 60 degrees, when the temp gets too low it confuses the thermostat and it shuts everything off, as long as the room is above 60 should work fine.
Sean
Mar 30, 2011 | Frigidaire Refrigerators
Freezer side works, other side does not cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you ti figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Both freezer and refrigerator temp variations
in most refridgerator cabins is a air dam at top right of side by side and it could be sticking open and working other times or it could get stuck in defrost cycle due to defrost timer not working properly.defrost timer would be first thing to look to.
Apr 20, 2009 | Refrigerators
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
Open Questions:
Frigidaire FRT125GW (12 cu. ft.) Top Freezer Refrigerator Logo
71 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
