Question about Stihl BR400 Backpack Leaf Blower
Pull string replacement - Stihl BR400 Backpack Leaf Blower
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Unless you are very handy, you might see if they sell the whole starter assembly, it would be faster.
Posted on Oct 19, 2013
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
How to change string?
If you look at the bottom of the string holder (flipping the machine over) there should be either two tabs on the side across from each other that you press and pull, OR a twist and pull. There are several pieces, the inner piece that the string comes on has a hole that the string goes into to hold the string in place (needle nose pliers--press into hole). Then there is an arrow on the string holder, just wind the string in the direction of the arrow (does not have to be perfect) until you get enough on the holder. Now, hold the string so that the spool does not unravel--feed the end through the hole(s) and replace parts as they came off of the trimmer.
I hope this helps.
Feb 09, 2016 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
My homelite (the shrub sharper 21) pull string broke. I want to replace string. How do I replace new string.
Replacing a pull string on anything is a tricky operation, taking it apart is easy, but getting the springs back in place and everything wound up is not easy. I would suggest finding a local hardware store or equipment rental location, and find somebody to do it for you. I made the mistake of attempting to do it, and 3 hours later and a lifetimes worth of frustration later I got it. Save yourself the trouble and pass it off to somebody else.
May 17, 2011 | Garden
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
Replace pull string (how to put string on after taking cover off)
Basically, pull the string through the winding hole and knot it off insuring no more than .25" tail on the knot and pull tight. :)
Jul 22, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Need to replace pull string on lawn mower
how do i change the pulling string on my toro 22 recycler
Jun 13, 2009 | Toro Lawn Mower With Toro Power Tools
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Bathroom heater: the string that turns it on came off
The string is actually attached to a bead chain. If the bead chain is still there, you can replace the cord with a new one from the hardware store. If she has actually pulled the chain out of the switch, I suggest you get a qualified electrician to replace the switch. They are quite inexpensive. (the switch, not the electrician)
Jan 22, 2009 | Kitchen Appliances - Others
Garden Logo
70 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
