Question about sausage maker Kitchen Appliances - Others
My D14 dehydrator went on for 5 seconds and then went dead. Nothing turns on. Could it be a fuse in the head controller unit?
  • 2,113 Answers
I haven't used my dehydrator much yet. Since i have repaired so many appliances in my life i could just assume that there is a thermal cutoff inside for safety to prevent fires. (conveniently for the appliance industry it also creates a higher failure rate hence more purchases). You can replace the thermal cutoff yourself if you can locate the common part from any decent electronic supply. Just look at the rating printed on it in fahrenheit or celcius. It either looks like a resister or possibly a button style like in microwaves.
Posted on Oct 18, 2013
  • josha
    josha Oct 24, 2013
    Thank you mikadot! I've attached a photo of the motherboard. There appears to be a wire connection that is brownish from heat connecting to the boars (Second from left) You think this is repairable or is the motherboard fried?
  • josha
    josha Oct 24, 2013
    picture loaded upside down. Wire is second from right in this image
While driving all the dash instruments went dead. speedometer , gas, temp gauge all went dead at the same time. radio, heater are working , along with the turn signals and blinkers, head/ taillights all...
Well, the fuse(s) or relay(s) exist SOMEWHERE in the vehicle. If you don't have an owner's manual, search online for "location of fuses for xx year, model."
Feb 08, 2018 | 1999 Chrysler 300M
Tip
Nesco Dehydrator Quits Working or Overheats
These Nesco dehydrators have a bi-metal thermostat. The surface of the contacts will sometimes corrode and stick together or short with the corrosion. It can be intermittent. This causes the unit to heat to a high temperature. This causes solder to melt or the thermal fuse to blow. Take it apart and clean the contacts of the thermostat with fine sandpaper or thin file. If needed the replacement fuse is a 5x12mm, 235 degree 2.5 amp 250 volt thermal fuse available from Radio Shack online or at store. An ohm meter will tell you if the fuse is bad.
on Jun 05, 2014 | Nesco 700W 5-Tray Professional Food...
2002 s-10...radio lights, clock and progaming shows up but nothing when i turn volume up
If you mean no sound, could be speaker wires are dead, output to the speakers on the head unit could be dead, if your system is fully amplified, that wire could have come undone.
First question: Is it stock radio?
Second question: no aftermarket items added to the system?
Third question: you mean no sound?
If the answer to all these are yes, test your cigarette lighter to see if it works. If it does, it's most likely the head unit or the stock amp. If it doesn't work, check the ACC fuse, sometimes there is a radio one too. Your head unit has three "power wires" one is constant (Unit turning on, time, etc. The second is the "switch" wire. The third is the ground. I am wagering the switch wire has a separate fuse. Hope this helps!
Apr 09, 2014 | 2002 Chevrolet S-10
I hadn't realized that an internal light was on and it was just sitting there for over a day. I went to turn it on and nothing came on no lights ,no dash board, no click. tried boosting it still nothing....
old post.
ok, no head lights, that means the battery is dead.
head lights are hot all the time, (safety) if they are dead
diagnosing HL is simple to do.
voltmeter to battery, oops 10v. bad. charge it.
many times leaving lights on, kills the battery for ever.
camel and straw deal.
1: dead battery , not 12.6v.
2: fuses blown. (in engine bay fuse box)
3: battery lugs corroded real bad.
Sep 20, 2013 | 2001 Honda Odyssey
Keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
In many brands, there is a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Oct 18, 2012 | Microwave Ovens
Gh9115xe went off completely sometime after a cup of coffee was reheated. Now, nothing works. The outlet is live.
probably not
there is a glass fuse under the outer case near the circuit board
if that is blown it is from a short so you may have to take it in for a diagnosis
Apr 28, 2017 | Whirlpool GH9115XEB / Q 850 Watts...
I have a rover cd32 radio /cd it was working fine i stopped for 5 minutes and when i started the car again the radio was dead.the fuse appears ok as the clock is working and are on the same fuse,pushed...
  • This shows a faulty head unit sometimes...
  • The fuses for these systems are usually two.
  • One right behind the music system, clock and the head works on it.
  • Then the second on the fuse box of the car.
  • Usually used fuse is the accessory- cigarette lighter kit fuse. Check for any blown fuse in the fuse box.
  • Then check the connection lines of the main supply(red\yellow), ground(black).
  • If this is not a remedy then go to the service center to get an advice. Do not open the head unit yourself !!
Sep 23, 2011 | Blaupunkt Car Audio & Video
Insignia ns-pdp50hd: power went dead, no standby
This could be your Power Supply Module or your Main board. I suggest taking it in for a diagnostic check.
Nov 17, 2009 | Televison & Video
2000 Mazda MPV radio is "dead"
try pulling all the fuses one at a time and see if any others are blown. if so replace.
Jun 23, 2009 | 2005 Mazda MPV
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Kitchen Appliances - Others Logo
331 people viewed this question
Top sausage maker Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a sausage maker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
