Question about Sharp Televison & Video
Hi I'm Alex good day my question is this: I sold a
Hi I'm Alex good day my question is this: I sold a plasma Sharp LC-52XU1 Limited Edition and I have no way to control and AUDIO COLOR MENU to enter these shows a chart that says (can not make changes that memory is fixed Cinema) and all the controls are a circle and a diagonal access no. . . What I can do and try to find a manual online but I have found no explanation has this fault or problem. Is there any solution or answer? My imel is tvcastillo62@gmail.com
    Scholar:
  • 35 Answers
I'm not really familiar with that model, but most televisions now have different "modes" you can put your television into. Common modes are Picture, Movie/Cinema, PC/Computer, and there are others. I would check to see in your Video or TV setup area if there is a Custom mode that you can set your TV too, as if it is set to one of the Pre-Set modes (it sounds like it is in Cinema mode) it would need to be taken out of the pre-set mode before you can make changes to the color and picture settings.
Posted on Oct 17, 2013
  • 53 Answers
SOURCE: no sound
When you turn the tv on, do you hear a faint “pop” noise from the speaker? If so, the problem is with the heat sink under the audio IC. Over time, the heat sink will lose its consistency and start to melt, thus shorting out the audio circuit. To fix, you’d need to clean off the melted residue on both sides of the audio IC as well as replacing the heat sink with a newly redesigned Sharp Heat Insulation Pad. It’s a pretty complicated fix, I suggest calling your local authorized sharp service center to fix this problem. The part is inexpensive, so you’re most likely looking at a labor charge (maybe around $200ish) for the repair if they are not marking up the price too much.
Posted on Mar 14, 2008
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
  • 50 Answers
SOURCE: remote does not work for Sharp lc42d85u
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug unit from back of unit
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug unit from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
If you get to step 7 and the remote still does not work then you need to replace the ir sensor board (aka) LED unit per Sharp.
if needed here is the orignal part info DUNTKE868FM01 about $12.00+ tax
Posted on Mar 18, 2009
  • 33 Answers
SOURCE: T.V. won't allow me to adjust color and sound...
Chepe_77,
You are absolutely correct. The reason why you cannot change your audio and video settings are due to the fact that you are in "Dynamic Fixed". Which is one of your many av modes. Av modes are different preset color settings and dynamic fixed is the only one that will lock your settings. Best Buy set it that way so that people could not just come by and alter the settings on the unit. AV modes are on all sharp lcd products and even though you have the wrong remote you should have an av mode button on the remote that came with it. Try pressing the av mode button and see what happens. When you press the av mode button, you will see your av modes change at the bottom of the screen. However, the issue still remains that you have the wrong remote. So there is a chance that you may press the av mode button on the remote that you have, but it still will may not work ONLY because you have the wrong remote. If the remote you have does not work, I GUARANTEE that pressing the av mode button on the proper remote will take care of that. If you dont want to purchase the remote from sharp, www.partstore.com is a good place. Good luck to you
Posted on Apr 17, 2009
  • 74 Answers
SOURCE: I have a Sharp LC-32D44E LCD TV. Purchased Oct
If the red light stays on and the tv does not react to any input from buttons or remote... the problem is one 7 pins integrated circuit on the upper side of the power board .the ic is situated on the right side of the power socket .It costs about 2$ and can be replaced by someone with mimimal electronics skills and a 30w solder iron .
Posted on Apr 20, 2010
I have a Sharp Aquos LC-70SQ15U that is about 3 years out of purchase.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 28, 2017 | Sharp Televison & Video
I need this part. Sharp AC Adapter for Sharp Aquos LC-15L1U-S Television part # UADP-A041WJPZ
Hi dickchrysler,
Click this LINK.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jul 14, 2011 | Sharp LC-15L1US LCD TV
From 1 to 10 ten been the best how good are this tv 55PP9363H/17 1 TOSHIBA 6211M15 1 SONY KFSOWE620 1 MAXENT MX26X3 1 SAMSUNG LN32BS40P8D 1 MAXENT MX26X3 1 MAXENT MX42XM11 1 SONY KDLS2VLISO...
The Samsung LN40B540P8F I would rate a 9. Only God is 10.
All the DLP sets, you can throw out
All the Older Projection sets you can throw out
I would take the rest for scrap parts.
I hope this is helpful.
Dec 18, 2010 | Philips Magnavox 51MP392H Rear Projection...
Sharp LC-37SH12U LCD TV is 20 months old and would not power on
Your power supply unit needs servicing on some part replacements. bad capacitors, voltage regulators, hi-watt resistors,....etc
Nov 03, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My sharp LC-19DV22U Will not connect to my PS3
well alex welcome to fixya technical support online.i just read your problems. there is an option to your problem you can use another cables with RCA inputs capable in your PS3 that can works on videos and also you can buy video converter. thanks!
Aug 14, 2009 | Sharp LC19DV22U 19 in. LCD Television
Sharp 20mu14
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Jan 23, 2008 | Sharp LC-15AV4U 15 in. LCD Television
Televison & Video Logo
149 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
