Question about HP DesignJet 5500PS InkJet Printer
Hp business inkjet 2230 there are bubbles in blue ink line. Do I need a new print head? THe ink is 2009. Maybe buy all new ink?
  • 63 Answers
Run a diagnostics tool - think on those machines should be a purging or cleaning tool
Posted on Oct 17, 2013
The Machine
  • 788 Answers
SOURCE: Hp Business Inkjet 1000 problem
Are you using HP branded ink?
Posted on Jan 17, 2008
agnelkj
  • 210 Answers
SOURCE: inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Posted on Mar 18, 2008
SOURCE: Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Posted on Oct 13, 2008
yooperbud
  • 8637 Answers
SOURCE: HP Business Inkjet 1200 printer always prints the Alignment Page
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
CompuFirm
  • 89 Answers
SOURCE: Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
Posted on May 27, 2009
After installing new ink cartridges, when printing black and white, every 4th line of text is only partially printed
Some of the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 15, 2013 | HP Officejet Pro 8000 Wireless InkJet...
I have a HP Office Pro L7580, model #C8187A. I am getting white horizontal lines across my documents. The white lines appear about every two to three inches. The top portion of the letters are missing
The black print head has a few blocked nozzles.
Apr 04, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
I have a Hp Office Jet Pro L7590 All In One. The blue ink will not work. I have replaced it and tried to clean it. Can I buy a new cartridge holder???? It works great other than that. HELP!!!!!!
Check the cyan ink supply line for air bubbles. These printers work off negative pressure between the print head and the ink supply. If there are bubbles in the line the negative pressure is disrupted and ink cannot flow through the print head.
Dec 15, 2009 | Office Equipment & Supplies
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Vista
Re: Vista and Print Server check out a reply from 2006 at:
I need HP Printer Driver for Vista - DriverHeaven.net
gave hint to use hp deskjet 5400 driver instead of the hp business inkjet 2230 driver i have been trying for days with my Netgear PS101 print server (v1?). Finally works, at least for a complete looking test page and the preferences for the 5400 printer seem clearer than those given for the 2230. maybe that is why print servers and printers are not working...it is the driver supplied by HP is wacko for vista?
Jul 12, 2008 | HP Business Inkjet 2230 Printer
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
Epson Photo RX620: Printing Pink Lines
None of these answers are accurate.  I know precisely what your problem is, and you aren't going to like what I have to say.  What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer.  I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue.  I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem.  The issue you are having is with the Epson print head, which uses piezo technology.  What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber.  It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet).  Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture.  Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy.  The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head.  It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head.  Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it.  If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not.  Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol.  However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed.  If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours.  If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem).  The solution is to acquire a new print head.  Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer.  Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge.  Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy.  Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
Oct 16, 2007 | Epson RX620 All-In-One InkJet Photo...
HP DesignJet 5500PS InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
