Question about Music
Casiotone 301 Hi, I need your help. My Casiotone 301 has broken the power supply. Can I repair it or buy one in any shop?. Thanks.
HI, Your unit is very old and it can be repaired. Look for someone who does vintage synthesizer repair. John, Syntronics.
Posted on Nov 12, 2013
danforddan1
  • 192 Answers
SOURCE: Need casiotone mt 36 manual please.
I went there as well casio.com/usa I would try the MA 150 many times the instructions are very close to each model. If this still wont help, try Ebay and Yahoo there a lot of manual collectors there . You may even get lucky on YouTube good luck DFD please rate me
Posted on Apr 11, 2009
  • 1137 Answers
SOURCE: Power input needle snapped on Casio CTK 1000
The answer is repair shop if you don't have tools or experience with soldering. If you do it is simple to take it apart and take the old supply jack out. Take it to an electronic parts supplier so they can match a new one up for you. Make sure that the holes in the circuit board are clean and free of broken pins. Make sure that the traces leading to the holes are intact. Do not use too much heat or they will separate from the board. It might help to take the adapter with you as the jacks and plug have to match in size.
Posted on Aug 06, 2009
  • 5603 Answers
SOURCE: I have a Casiotone MT70 made in 1984. How do I
Here is how you might check the polarity of a 7.5 volt DC replacement adapter:
Put the 5 batteries into the unit and verify operation. NOW using a DC voltmeter measure the voltage from battery negative and meter negative connected and meter positive to the pin on the power jack. IF you see 7.5 volts positive, then the pin is the positive lead for the adapter.
If you see zero, then continue testing.
With the 5 batteries inserted, connect the positive meter lead to the positive of the stack of batteries. Now touch the negative meter lead to the pin.
If there is 7.5 volts there, then the pin is the negative lead for the adapter.
READ THESE INSTRUCTIONS CAREFULLY.
USUALLY the jack has a contact that disconnects the batteery when the plug with sleeve is inserted.. We are testing the jack without inserting a plug here so the plug should HAVE THE BATTERY VOLTAGE with correct polarity on the pin.
Posted on Oct 08, 2009
Testimonial: "Very clear explanation for a non-techie to understand. Many thanks."
  • 5603 Answers
SOURCE: Need an Owners Manual / Users Guide / Operation
You can download a copy at this site... one has to join it for a very nominal fee... about $2 which is worth it...
http://filez-express.com/download.php?file=casio%20mt%20500%20manual
Posted on Dec 10, 2009
  • 1137 Answers
SOURCE: manuals casiotone 501
Try looking at this site:http://www.casio-europe.com/euro/support/repair/emi/ I don't know what country you are in so this is your best bet.
Posted on Feb 03, 2010
Loss the plug for my casio casiotone 301where can I finde one
I believe that uses a standard "IEC" power cord like you would use on your PC. Try Best Buy, Radio Shack or mouser.com(if using mouser try part number: P006-006 and look at the datasheet ),
Apr 28, 2014 | Music
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Casiotone ct630
I haven't been able to find documentation to be sure if the CT-630 has MIDI ports on it (my guess is no, but please check). If it does, you can get something like the Yamaha UX16 USB MIDI Interface cable to connect the keyboard to a PC.
If not, sorry, it seems the only thing you could do is record the audio output.
Aug 17, 2013 | Music
Problem with power transformer for my casio casiotone 403 electronic keyboard,don't know all the secondary voltages
Transformers are exceedingly reliable. Are you sure it is a problem? Also transformers can be rewound. I have tried to find a schematic but have not had success. Most power supplies in music equipment have only a singel secondary, usually with a center tap.
Mar 28, 2011 | Music
Casiotone MT-220 keyboard power cord
I would inspect the unit for corrosion on battery terminals AND the power connector. The connector has a switch when a cord is plugged in, and if this switch doesn't work (they get bent) the unit will not work on batteries.
Best source of power adapters is often your local thrift store.
MATCH the voltage and whether it is AC or DC required AND the polarity if the pin is + or -.
Get one with enough current.
Apr 28, 2010 | Music
I need a spanish user manual of casiotone mt 70
http://www.manualsnguides.com/search.php?cmarque=CASIO&modele=CASIOTONE%20MT-70
Apr 13, 2010 | Casio Music
Manuals casiotone 501
Jan 28, 2010 | Music
Apr 10, 2009 | Casio Music
Music Logo
236 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
