Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool frontload washer fills with water, then beeps. I push the start button and it will drain and then shuts off completely. Then I turn the knob to rinse/drain, it drains and spins, but my clothes never actually go through the washing phase. And my bleach and fabric softener compartments are filled with water.
  • 4 Answers
This is what mines doing too!. any takers on how to fix? I am just about to strip mine down to look for a blockage in the water lines. wish me luck.
Posted on Oct 17, 2013
  • 85 Answers
SOURCE: Nothing wierd...just no rinse/no spin/no drain with the whirlpool
sounds like you have a bad lis switch asm.
Posted on Dec 16, 2008
  • 99 Answers
SOURCE: WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Posted on Feb 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Posted on Feb 08, 2009
SOURCE: Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Posted on May 24, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
WHirlpool wtw6600
HI,
Unplug your washer and open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass through it should not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there should be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
Aug 26, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Lg frontloader washer - wont start. I tried pressing all the buttons / no lights display/ looks like there is no power / i already tried the breaker / nothing - can you help
  1. If the washer won't start, check the power cord or reset the circuit breaker depending on the issue. It may be overheated and shut off temporarily. Let it cool for 30 minutes, and if it still won't start, call a professional.
  2. Step 2 If the motor transmission failed or the drive belt has broken, these need the assistance of a professional.
  3. Step 3 If the washer won't drain, clean out the drain hose and straighten any kinks. If the drain hose fits too tightly in the standpipe, adjust it to allow for a minimum of 1.25 inches for airflow so water can drain.
  4. Step 4 If the washer won't fill or fills slowly, turn the faucet handles counterclockwise as far as possible. This is usually the result of partially open faucets.
  5. Step 5 Call a profession if the washer overfills. This means the water-inlet valve or switch is defective.
Any further help, let me know.
Thanks.
Jun 18, 2009 | LG WD-16115FD Front Load Washer
Hi!
“F20” on display
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dishwasher adg7540
where do you live that model doesnt come up in my data base the first thing your washer should do when you turn it on is drain then fill then go to wash try this it should put it in self diag if this dont work reply we will try another HIGH TEMP SCRUB, AIR DRY, HIGH TEMP SCRUB, AIR DRY push thoose see if it goes into self diag
Jan 24, 2008 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool Duet GHW9150P Front Load Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
