Question about Dryers
Furnace fan wont run - Dryers
  • 3 Answers
CHECK FOR POWER, MAKE SURE THE SWITCH IS ON, SEE IF IT TURNS ON FIRST, IT COULD BE A FUSE ON THE CONTROL PANEL..OR IT COULD BE A BAD SWITCH ON THE SURFACE, OR LOOSE GROUND WIRE..MAKE SURE YOUR UNIT IS GETTING POWER!
Posted on Oct 17, 2013
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
My furnace wont turn off
Well Linda, is it the heat portion will not shut off or just the fan in the furnace that continues to run?? If the heat won't shut off, it will get uncomfortably HOT in your house, if its just the fan.....well, its just the fan.
More than likely its just the fan and it is running continually due to a stuck set of contacts in the control board or in the fan control board, if so equipped. If it is a furnace that is older than 15 to 20 years, it could be a mechanical relay that controls the fan directly off another control in the furnace vestibule that senses heat in the heat exchanger. If its an electric furnace, the first stage heat sequencer could be stuck closed causing continual fan operation and possibly one heat element is also energized. There are also several additional issues that could be the cause.
At any rate, its time to contact a reputable service entity to correct your problem. Good luck, Linda.
Dec 04, 2015 | Heating & Cooling
04 goodman furnace model GMS8 ciculator blower wont stay on gas fires and runs but high limit trip because of no air from blower any ideas bad motor or control module
You need to check the motor amp draw against the spec tag on the motor. If the motor has power to the motor wires it's either the motor or the run capacitor.
Nov 17, 2014 | Heating & Cooling
Where is my flame sensor on a single burner coleman evcon high efficiency furnace
If this is a hot surface ignition system, the sensor may also be your igniter.
Dec 11, 2013 | Heating & Cooling
Pleasureway Traverse furnace fan runs when funace is off.
Bad/ stuck fan relay or temerature sensor is not shutting the fan off. Or there is a short on the low voltage fan control circuit. Check to see if the Green terminal is jumpered to the Red terminal at either the furnace control board of the 'stat, if not, ohm the wires with both ends off- I've seen installers accidently shoot a staple thru the wire and short the wires together more often than even I can believe! Hope this Helps! PS Some furnaces have fan switches inside the furnace- check for one and see if it's "on"- sounds too simple, but sometimes the "simplest" is the correct answer.
Mar 22, 2013 | Heating & Cooling
Fan wont run on auto
Make sure your tstat is programmed for electric, not gas. Or in the settings you want that the TSTAT CONTROLS THE FAN.
May 23, 2017 | Dometic Rooftop RV Air Conditioner
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
Air conditioner/furnace squirrel cage fan remains running when th
Ensure you don't have a short in your therm wires. Disconnect them, if the furnace continues to run, you have a lockout problem at your furnace. When the motor on the fan fails, it wont run. Check for led codes on the control board. If you don't have led codes, turn off the power to the furnace at the breaker, and watch the unit. If nothing happens, connect the thermostat. If nothing happens still call for heat. Let the therm run through it's cycle, and if the bower runs continuous again, let me know we can walk through that situation.
Dec 05, 2008 | Ruud Central System Air Conditioner
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Dryers Logo
23 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
