Question about Dishwashers
I have a kenmore dishwasher quitewash1 it will not get power or come on
    Master:
  • 492 Answers
Make sure the circuit breakers to the dish washer are on. Cycle them off then on to make sure. This will reset the GFI breaker. Plug the machine into the wall plug and make sure the wall plug in not a GFI also. If it is reset the wall plug and you should have power.
Posted on Oct 17, 2013
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Kenmore dishwasher panel isnt responding
>> Unplug dishwasher power cable from wall mount also from dishwasher (if applicable).
>> After 10 minutes - plug the power cable from dishwasher to wall mount
>> Turn on the dishwasher
>> Try to operate the panel.
Mar 29, 2014 | Kenmore Dishwashers
Power went out and now dishwasher will not restart
Try unplugging your dishwasher and waiting 30 seconds, and then plug it back in. See if that helps.
Nov 23, 2011 | Kenmore Dishwashers
Cannont get dishwasher to turn on. Kenmore 13843.
it is most likely the door latch switch
Jul 31, 2010 | Kenmore Dishwashers
Kenmore dishwasher no power
Check the following areas for faults.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer or control board
Replace if defective (note: uncommon problem).
4. Selector switch
Jun 14, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore dishwasher power cord.
The green is the ground wire. Attach it to the screw inside the junction box.
Feb 20, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
Jun 22, 2008 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
