Question about GE 3.9 cu. ft. Stainless Steel Capacity Washer GHWN4250DWW
Ge GHWN4250DOWW washer tub seems loose and "off kilter" making a horrible racket when spinning
  • 3 Answers
Could be bad shock absorbers. Google that washer model number, and at the same time shock absorbers, and see if it has them. If it does, I bet their broke. Ebay 10 - 30 bucks. easy fix. Good luck
Posted on Oct 17, 2013
Testimonial: "Thanks. I took some the panel screws out and did a little digging today. There are these rubber straps that basically give the tub "wiggle room". They stretch from the frame to the tub, allowing the tub to move, but only so far. Where the rubber goes onto the tub, it just slips over a plastic post and then a screw holds it on. One of mine was missing the screw. You can see it by prying off the "add bleach here" cup and then just pushing the tub to the side. Funny thing is the screw was no where to be found. So I just slipped this rubber thingy over the post and thought I would give it a spin. (pun intended) I was not sure that such a little thing would make such a big difference, but it did. I have washed 4 loads today and it sounded nice and quite, just like new. I will eventually pull the thing back out and put another screw in it, but for now it's working. I believe the intial issue was a really bad off balance load that caused this dude to pop off in the first place, something like a large bedspread or sleeping bag, who knows. Thanks again for offering your reply."
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
My GE stackable washer is pouring out water while filling up, when spinning makes horrible noise and tub goes crazy
The issue is that a shock or spring that balances the tub has come loose and pulled a hose off when it broke. So the shocks or the springs are bad. The hose might be able to just be put back on.
Feb 23, 2015 | General Electric GE 5.4 cu. ft. Large...
Haier hlp23e jolting noise spin
You need to level it again. (the knobs on the bottom of it are threaded so you can adjust them to make them level, it can be time consuming, so it is best to start with the one that is shortest.
Mar 23, 2014 | Haier HLP23E Top Load Washer
GE top load profile washer won't spin. It starts
The tub hangs on 4 support rods. Lateral movement is kept in check with 4 bungy cords bolted to the top of the tub. If that washer is not level the tub will hang to one side and the fancy controls will declare an error. Make sure all your rods are good (they drag the base of the machine when worn out and make a heck of a racket) and the bungys are not stretched and the machine is level.
Aug 04, 2012 | Washing Machines
How do I remove the agitator for my machine ? It is loose and spins fine, but makes a clanging noise when agitating counterclockwise during the wash cycle. It seems like I just need to tighten it down...
Anyone with loud scraping/clanging- we had that problem and saw that the large wheel the belt goes around is only an inch above the metal bottom.When we moved the washer with a 2wheeler it pushed the bottom up into the metal wheel. The racket it made was horrible. It left metal shavings ,too. You'll need to pull the bottom of the washer back out.Pull fromt panal off with putty knife.You'll need to lean or lay washer to one side.Put a pillow or cushion inside between the tub and housing side you'll be leaning towards. What I did was drill two little holes-one near the back center and one near the front center. I took a long piece of heavy string,put one end in one hole and the other end in the other hole-outside to inside.Tie the ends around each end of a 1x2,18inch board .Get the board to the back without damaging stuff inbetween-pulling on your back string for help. Make sure the board is against the bottom, get to where you can now pull your string 'handle' w/both hands,yanking and popping the bottom back out.Our washer now works beautifully and quietly.
Feb 12, 2011 | GE 3.2 cu. ft. Washer
The washer made a horrible noise and the tub seems to be loose from the machine. Can I fix it? The tub in my Frigidaire stacked washer all of a sudden with a fairly heavy load of jeans started making a...
you need to remove the agitator and check the bolts that hold the trunion to the shaft and make sure they are not broken.if one is just replace them make sure that the bracket is in the flat key way on the tub hope fully the tub seal is still good.
Oct 15, 2010 | Frigidaire FEX831CS Top Load Stacked...
I have a whirlpool duet front loading washer and during the spin cycle it makes a horrible thumping noise. It seems like the drum inside is very loose as well.
you may have a broken shock, remove lower pane with a 1/4 socket or nut driver, once you have done that you should see 4 shocks at each corner of outer tub, if one has come loose or broken it will sound loud when in spin, it should be easy to notice
Sep 20, 2010 | Washing Machines
Machine does not spin, it only makes a horrible racketing noise
Sound like you have a busted coupler .It is located between the motor and trany.Cheak inbetween .hope i helped.:)
May 18, 2009 | Kenmore 22422 Top Load Washer
GE 3.9 cu. ft. Stainless Steel Capacity Washer GHWN4250DWW Logo
176 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
