Question about Gemmy Halloween 2010 Gemmy Nightscape Jack O Lantern
Gemmy halloween grave riser will not raise up and down
2 Suggested Answers
SOURCE: we have a gemmy fortune
halloween gemmy 2009 life size moveable witch need manual instructions
Posted on Nov 27, 2010
Gemmy whirling ghost Halloween projection light can't find on switch
its not a solar job is it
cant see any on /off switch on the globe projection part
does it have a wall plug wired to it
Oct 11, 2016 | Televison & Video
Bought the whirling ghost projection and can't find on switch only works in demomode
cant see any on /off switch on the projection or globe part
only a wall plug
typical walmart product ...no user manual
Gemmy Lightshow Projection Whirl Motion Ghosts Halloween Decoration...
My Halloween skeleton airblown train from gemmy im having problems with it and don't know what to do the skeletons arm is not waving and the ghost doesn't come up right
Check for something blocking the rising ghost. It really sounds like you might have a leak someplace. Check for holes or tears, especially on the seams. I have found clear packing tape works pretty well for a temporary fix.
Oct 10, 2014 | Toys
How do i raise the handlebars on the gt 3.0
Most bicycles have adjustable handlebar risers. Just loosen the center riser bolt 4 or 5 turns (you may have to use a mallet or hammer to break loose the draw nut from the neck) then raise it up "no higher than the max line indicator". If you still need it higher search for an extended riser or more suitable handlebars.
Sep 27, 2014 | GT Avalanche 3.0
My gemmy dancing santa bear wont move any more i need help
I is very good that the http:www.molitop.com goods,You can take a look at Lady Gaga Halloween Costume Kit, you should be satisfied.
Oct 15, 2012 | Gemmy Life-Sized Animated Santa
Can handlebar for ccm vandal xc 26" bicylce be raised? It seems as if stem is confined by top and bottom bearings. Doesn't make sense that seat can be raised but not handlebars.
The threadless stem style you have pre-supposes you chose the right height and reach when you bought the bike. As the steerer tube to which it clamps has to be below flush with the top surface to accomodate the top adjustment cap, the steerer had to be cut to a final length that can't be made longer. The stem CAN be flipped upside down to provide a different rise and reach, but most likely it would be lower and farther away.
One option is to replace the stem with one with an angle and length that would work for you. Have a bicycle shop asist you in choosing one as there are 4 parameters that must be considered.
Another is to get a threadless stem riser which effectively makes the steerer tube taller. Google "threadless stem riser".
Here's one on eBay...
http://cgi.ebay.com/New-SATORI-HEADS-UP-Threadless-Stem-Riser-Adapter-1-1-8-/300530665912?pt=Cycling_Parts_Accessories&hash=item45f90609b8
Mar 18, 2011 | Cycling
I have a 5' Singing Dancing Skeleton by Gemmy Industries purchased at a WalMart...Lost instructions to unlock it into standing (non-storage) posistion.
Remove the locks from the bottom. They look like the base for one of those solar lights you put in your yard. Once they are removed, push down on both shoulders at the same time and it will spring up! Hood luck and Happy Halloween!
Oct 14, 2010 | Toys
Gemmy Halloween 2010 Gemmy Nightscape Jack O Lantern Logo
Top Gemmy Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
