Question about Kenmore Dishwashers
Have a portable dishwasher that is not getting any water into the machine-lines seem to be clear.When turned on machine makes a screeching sound but no water getting through.What is the problem/solution? Thanks Larry
  • 45 Answers
If the lines are clear then the solenoid is not letting water in. It sounds like the pump is dry ( that noise). The water lines are removable so you could check that first. The solenoid is replaceable ( on the underneath side) on regular dishwashers. Yours might have a sheet of metal over the bottom because it rolls around. I'm sure you could replace that part, but it would be difficult if you have not replaced parts on appliances before. Not much in tools although some require star drive or similar. Hose clamps and probably one electrical quick connect. If you do try it, take the model number And the serial number to a good appliance parts store and ask. Also ask for an expanded view of the area that should give you the way to replace that part.
One more thing parts are not returnable so you must be sure this is what you want to do.
Hiring a repair person starts at 65-75 dollars just to come out, plus (triple cost on parts) plus labor time to do it. That part could be as little as 20 bucks.
Posted on Oct 17, 2013
4 Suggested Answers
  • 105 Answers
SOURCE: Candy Nova CD112 dishwasher
not enough water in machine
do you have hi or low pressure
when machine is washing try adding a extra litre of water manually eg milk bottle or jug
note the sound of washer before and after
if this improves then that is problem
Posted on Feb 24, 2008
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
  • 70 Answers
SOURCE: I have a Miele Inspira line dishwasher and it is
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Posted on Apr 12, 2010
Testimonial: "It worked!!! Thank you very much."
Portable dishwasher is not getting water with water turned on. It makes a screeching noise. what is the problem?
Too little information. Could be a water pump valve not opening or the pump itself.
Oct 17, 2013 | Dishwashers
I do not seem to get sufficient water pressure in the machine.There is sufficient pressure at the faucet adjacent to the machine. Is there a filter that could be removed and checked for debris in the water...
there is a screen in the water control valve try disconnecting water line at the d/w with water turned off after line is off get a bucket and turn water on to see if there is good pressure if there is good pressure I would say it is the water control valve
Oct 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
Kenmore portable dishwasher not performing.
There are likely more pieces of glass in the impeller of the motor keeping it from turning. It will have to be disassembled and cleared.
Eric
Jun 10, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Doesnt clean dishes, seems to be no water coming into machine
There should be about 2 inches of water in the bottom of the DW.  If it is filling but not washing the pump may be bad.  That might explain the loud noise (motor bearing).  I assume that the detergent cover is opening but no water is being sprayed to dissolve it.
May 31, 2009 | Dishwashers
Kenmore portable dishwasher not working
if you can get underneath it try spinning the motor manually (after turning off the circuit breaker). sometimes the motors on dishwashers get jammed.
May 29, 2009 | Kenmore 22422 Top Load Washer
Sounds like it's running but no water seems to be getting to it
Your drain m ay be clear but it sounds as though the dishwasher line may now be clogged, remove the dishwasher drain line from the trap below the sink and check for leaks. You drain nthe dishwasher into a bucket.
Mar 20, 2009 | Dishwashers
New Garbage disposal, washing machine and dishwasher won't work.
Does not sound like these problems are directly related to the disposer. Grinding sound is most likely the impeller on the washer's pump. The washer gets to the first pump out and is unable to pump due to bad impeller or an obstruction. Bad impeller means replace pump motor. (not very hard) Check water supply to dishwasher. Valve turned off or line kinked? Filter screen at solonoid valve plugged?
Aug 15, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Aug 05, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Zanussi built in aquasave zt 685
I think I had a similar problem to this. It seems like it was starting a cycle but then it just stalled and made a buzzing noise and it did not drain properly. I opened the bottom of the dishwasher where the draining pump was located. take off the plastic cover and I found bits of broken plates were jamming the fins on the pump... Try this and see how it goes.. Hope it was of some asistance.
Mar 14, 2007 | Zanussi ZT485 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
