Question about Canon IS Binocular
Battery door broken on my 10 X 30 IS canon binoculars, how to remove post to replace new door?
2 Suggested Answers
  • 4 Answers
SOURCE: hello I need to replace the
This answer may only apply to Canon 12x36 IS II 5
To replace the battery cover you will need to split the central case.
To split the central case you will need to loosen the two very small philips screws located deep in the holes on each side. Then you need to remove the single philips screw between the adjustable oculars just below the focus knob. Finally remove the plastic name plate carefully since it is held on with double face tape. At this point you will carefully pry all around the half with the battery door off of the main body. It does not come off easily and there is no reason to remove or do anything to the objectives, focus knob or the eyepiece components. Once you have the cover off you will need to un-bend the battery door keeper tab so it slides through the slot and then remove what is left of the old battery door and at this point you install your new door and replace the keeper by doing a re-bend (best to buy a new keeper) finally install the cover. Not an easy fix and is a lot harder if you try to remove the oculars. Hint to remove oculars remove rubber covers first. Note that there is a plastic retainer outside of the objective lens tube to remove. Then roll the rubber off from the body to the objective. With these removed the rest will be obvious. On a easy (1) to hard (5) scale this is at least a 4.5.
I know this does not apply to the 18x50 IS UD 3.7 all weather since it has a rubber wrapper all over the body and objectives. But if you remove that rubber wrapper you may get there eventually.
Posted on Feb 01, 2016
Need repair of Canon 15x45 IS binoculars
That is bad and I am surprised. Canon Canada is just down the street from me!
There are lots of binocular repairers here.
binoculars Google Search
Mar 06, 2017 | Zeiss Optics
Canon A75 Battery door
Never did it on an S1, but on other models it required removing the back face of the camera to access the battery doory hinge pin.
Examine your camera, and if this sounds feasible, remove all screws along the perimeter of the camera (keeping track of their sizes and where they came from, write it down with a crude drawing of their locations/sizes). Also look for screws in the battery compartment, and any visible screws behind flaps/doors. Once all perimeter screws are removed, you should be able to remove the back face of the camera by prying it open from the bottom. Once opened, the pin holding the battery door should be able to be slid out, enabling removal of the old door. Then in reverse slide the pin into the new door, and reassemble the camera and its screws.
May 06, 2008 | Canon PowerShot S1 IS Digital Camera
10X35 IS
Check battery polarity (in the right way round ?). Check the battery is are actually OK (not dead .. 'brand new' can still be dead) ...
If no fix, take it back to the place you bought it ...
Dec 16, 2007 | Canon IS Binocular
12x36 only one eyepiece focus
Assuming you have already tried replacing the battery, contact Canon Service Dept.
Nov 18, 2007 | Canon (12x36) IS II Binocular
There is a pin that holds the battery door down, it might be removable without taking the case apart, other wise split the case and remove the pin and put the new door.
http://www.darntoothysam.com/servlet/the-1176/Canon-PowerShot-A75-Digital/Detail
has a battery door for you if you need it.
Nov 16, 2007 | Canon PowerShot A75 Digital Camera
Canon IS Binocular Logo
74 people viewed this question
Top Canon Optics Experts
old marine
old marine
TC CAMERA REPAIR.Com...
Are you a Canon Optic Expert? Answer questions, earn points and help others
