Question about 1992 LEXUS SC300 229501 Flywheel - Replacement Plate
1999 Lexus RX 300 blinking brake light and turning on and off brake fluid is good, brakes are good. What is the problem?
  • 2,113 Answers
Have a look at these items. Perhaps it could just be a faulty sensor.
Posted on Oct 17, 2013
Brake lites will not turn off, where and how do I replace the sensor
My brake lights won't turn off Help!!!!! - Club Lexus Forums
www.clublexus.com/.../592044-my-brake-lights-won-t-turn-off-help.ht...
Sep 13, 2011 - Join Date: Oct 2010 ... there is a switch on the brake pedal that operates the brake lights, ... take a look. my hope is it helps people get into their Bible where the Holy Spirit can teach them the REAL truth, not my words, which are .... 400/ 300 Classifieds (98-05), RX350 / 330/ 300 / 400H / 450H Classifieds ...
Rear Brake Light Dash Warning Won't Turn Off - Club Lexus Forums
www.clublexus.com/.../468853-rear-brake-light-dash-warning-won-t-tur...
Dec 9, 2009 - Rear Brake Light Dash Warning Won't Turn Off SC- 1st Gen (1992-2000) ... Do you have the correct tail lights for your model year? Do you a ...
[PDF]List of Warning/Indicator Lights - Lexus Drivers
Jan 30, 2016 | 2010 Lexus RX 350
1999 lexus rx300 brake light on dash stays on & warning ding ding ding?
check that the light is not referring to the hand brake adjustment as well
Dec 09, 2014 | 1999 Lexus RX 300
No brake lights 2002 lexus
It is very easy first check brake switch for continuity when depress and no continuity when press and check for fuse and circuit
Dec 11, 2013 | 1999 Lexus RX 300
The location of the brake light sensor on a lexus rx300 1999 yr the brake lights will not come on when brake is pressed i changed the bulbs the brake switch and fuses so the brake light sensor is the...
it's in the driver side of the luggage compartment, behind the panel that has the power outlet. You would need to remove the trim panel and follow the harness to get to it. Most of the time it's Gray color.
Sep 28, 2010 | 1999 Lexus RX 300
My brake light keep blinking and its making beeping noise?
check the brake pads or the level of brake fluid
Sep 16, 2010 | 2000 Lexus RX 300
2000 Lexus RX 300 - VSC Light comes on and brake pulsation
you most likely have an "air gap" or "tone ring" problem with one of your sensors or tone rings. i would suggest letting a technician diagnos which problem it is, as it is a diagnosis that requires some experience.
Oct 20, 2009 | 2000 Lexus RX 300
What is the cost of a 90000 mile service for a Lexus RX 300?
$700
timing belt
idler pulley
water pump
timing belt tensioner
valve cam gasket
coolant flush
spark plug
oil change
pcv valve
tranny oil change
differential fluid cahnge
drive belt
upper/lower radiator hose
brake system flush
air filter
good luck,i hope this help pls dont forget to rate me thanks
Jun 05, 2009 | 2001 Lexus RX 300
Brake lights in-op. light bulbs replaced. looking for location of brake light relay
you have have a bad brake lamp switch very common its located on the brake pedal
May 30, 2009 | 1999 Lexus RX 300
1992 LEXUS SC300 229501 Flywheel - Replacement Plate Logo
Top Fidanza Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Fidanza Vehicle Part and Accessory Expert? Answer questions, earn points and help others
