Question about Sub-Zero 690 Side by Side Refrigerator
I have a kenmore side by side model # 106.57362700 and the freezer wont get cold enough to make ice.
2 Suggested Answers
SOURCE: sub-zero model#3211-rfd, side by side,
Have you cleaned the coil? Pop the grate off the top of the fridge and vacuum the coil as well as the grate thoroughly.
J
Posted on Sep 16, 2008
Why is my freezer not cold enough?
Check the freezer door seal is not leaky. Look for signs of moisture condensation along the door. Apply a thin film of Vaseline along door frame. This will make door seal stick better.
Also check there is no ice building up in freezer. This is a self defrosting fridge and built up of ice inside means warmer temperature. Lower the use of ice cubes from the ice maker to reduce load on compressor as this can effect freezer temperature.
Check freezer is not full of too many items causing reduction of air flow and hence reducing cooling effectiveness.
May 01, 2014 | Kenmore Refrigerators
Kenmore side by side model #59432 is making ice very slow
Is the freezer cold enough? Should be close to 10 degrees
, lift the cut off arm and let it drop to see if it will start. It may not be making the switch to continue the ice making cycle.
Aug 17, 2009 | Refrigerators
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
Refrigerator not cold enough(65*)
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Refrigerators
KENMORE COLD SPOT REFRIGATOR/FREEZER,MODEL 106 52542101,WILL NOT EJECT ICE (SIDE BY SIDE)
hi thanks for the question if the ice cubes are formed in the tray nicely then you need a new ice maker if the whole ice tray is a smooth sheet of ice the freezer might not be cold enough empty out the ice manually ant try again &lower the freezer temp thanke the appliance doc
Sep 17, 2008 | Refrigerators
Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Jan 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
19 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
