Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My Whirlpool AWE2316 washing machine is showing F12 error, which means that i should check the wiring. So i did and everything seemed fine, but i think that the centrifuge causes the connectors to come loose. What should i do?
  • 3 Answers
Silicone them in place.
Posted on Oct 17, 2013
the dr
  • 447 Answers
SOURCE: Whirlpool washing machine model GHW9460PWO, error code 11F
Yes it may be in the MCU but I had one do this and it was in the CCU. Has it ever thrown a Fdl ??? Door lock code?? Thats another sign its in the CCU
Posted on Jan 04, 2008
  • 1550 Answers
SOURCE: the error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Posted on Feb 21, 2009
SOURCE: i have F12 showing on the panel, the machine wont
his problem is usually caused by what we professional servicemen call, "Frillies in the drain pump." 'Course, that's just generic talk for something that isn't supposed to be there. What you need to do is below.
- Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump.
Below is your service and repair manual.
http://www.eserviceinfo.com/downloadsm/17628/Whirlpool_AWM8143.html
Another link below showing parts diagrams etc.
http://whirlpoolwasherparts.estanciacatariri.bolivia.hardomonia.com/whirlpoolwasherpartsdiagram/
Posted on Aug 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: I've a AWM8050 Whirlpool washing machine. The
f8 is shown when the heater circuit is on with no water in.. it doesnt do it when you unplug the pressure switch because your disabling the heat protect circuit
THE BOARD IS PROBABLY FAULTY
F08 indicates pressure switch stuck on full.
Unplug the appliance from the wall socket.
Take the top off the machine.
Locate the pressure switch, you can identify it by the thin tube attached to it.
Take the tube off, blow down this tube as hard as you can to shift any blockage or restriction in the pressure chamber. Give the pressure switch a couple of good taps with the screwdriver handle.
Refit the tube and try the machine again.
If still doing it, unplug again and follow the tube down.
This end will be attached to the pressure chamber.
Take this chamber off and thoroughly clean it out, clean out the port into the tub too.
Reassemble and try again.
If after this it's still faulty you'll need to start replacing parts.
I'd suggest trying a new pressure switch first.
Failing this, if all of the above fails to resolve the problem you're possibly looking at a faulty main control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
rickead1
  • 1998 Answers
SOURCE: My Whirlpool Duet Front Load Washing Machine is
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Posted on Jan 16, 2011
    What does F09 mean mean for a whirlpool AW0 3561 front loader?
    Washing Machine Fault Cod Fault
    FH No Water Inlet
    FA Aquastop Failure
    FP Drain Failure
    F5 NTC Failure
    F6 Tachometer Failure (no motor movement detected)
    F7 Triac Short Circuit detection
    F8 Heating Element, Open Circuit
    F9 Overflow Failure
    F10 Motor control unit (Thermal)
    F11 Communication failure
    F12 Heating Element Short Circuit
    F13 Dispenser Circuit Error
    F14 EEPROM Failure
    F15 Motor Control Unit Error
    F16 Control Failure (Control Unit)
    F18 Control Failure (Control Unit)
    F20 Control Failure (Control Unit)
    F21 Control Failure (User Board)
    F22 Control Failure (User Board)
    FDL Door Lock Error
    FDU Door Unlock Error
    Whirlpool Washing Machine Fault Codes
    So the answer is Overflow Failure
    Apr 13, 2015 | Whirlpool Washing Machines
    My whirlpool cabrio washer won't start but doesn't show an error code
    How old is the machine if its and older modle the switch probably just went bad which is an inexpensive and easy fix
    Dec 27, 2014 | Whirlpool Washing Machines
    What does and F6 error code mean on a whirlpool duette front loading washing machine mean and how do I fix it?
    Error code F06 means Drive motor tachometer error.
    The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
    Potential Causes
    1/ Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
    2/ Check the Drive Motor
    3/ Check the MCU
    4/ Check the Wire Harness
    Replace failed component or contact an authorized repair agent.
    Oct 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    P.c.b. not working
    Washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.
    Oct 21, 2012 | Whirlpool Washing Machines
    Showing F01 error code on readout? what does that mean?
    Hi.
    It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
    With Hotpoint F01 means defective triac or defective motor.
    Aug 18, 2011 | Washing Machines
    Code f12
    Hi, F12 means a communication error .Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    Potential Causes
    • Check Wiring Harness connections to the MCU, the motor, and the Central Control Unit (CCU)
    • Check the Drive system
    • Check MCU
    • Check CCU
    • Check Motor
    Replace failed part
    Take care
    May 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    HDW 1011WG machine showing a F33 fault
    The error F33 means Pump Drive System Error occurs when the connection between pump and the Central Control Unit(CCU) is lost.
    Follow these steps.
    1. Unplug washer or disconnect power.
    2. Check wire harness connections to the pump and Central Control Unit(CCU).
    3. Plug in washer or reconnect power.
    4. Verify CCU operation by running a Diagnostic Test or any cycle.
    Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Washmachine F11Code
    The error code F-11 on your washing machine means:--
    Serial Communication Error
    both this parts needs to be checked.
    You will have to check the following to confirm where the fault exactly is:---
    Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU).
    Check the Drive system for any worn or failed components.
    Check MCU.
    Check CCU.
    Check Motor.
    Check Wire Harness.
    You can get required parts from www.repairclinic.com
    Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool washing machine really loud
    hi there,
    error f06 means Drive Motor Tachometer Error
    The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
    for this u may
    • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
    • Check the Drive Motor
    • Check the MCU
    • Check the Wire Harness
    Dec 10, 2008 | Whirlpool AWM6100 Front Load Washer
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    119 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
