Error code 2000-0151
Dell laptop gives the error that there are no bootable device. when running onboard diagnostics it says there is no hard drive installed. When doing it the second time it gives the error code 2000-0151
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
Give some more information, like have you installed any operating system before, or made changes with operating system, which operating system this come with?
Posted on Oct 17, 2013
Testimonial: "I did not make any changes. The laptop is a Dell inspiron 14 7000 with windows 8 which i received today. After starting it up and going trough the start up i rebooted. And now i have the problem described above."
Geekman
  • 32281 Answers
SOURCE: No Bootable devices Dell Inpiron 6000
Yes time for a new hard drive.
Posted on Mar 31, 2009
  • 3940 Answers
SOURCE: i get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Posted on Dec 11, 2009
computus
  • 487 Answers
SOURCE: have a Dell Inspiron 1525
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Posted on Aug 04, 2010
  • 2291 Answers
SOURCE: i ran a diagnostic on
check this
http://en.community.dell.com/forums/p/19…
try repair ur os , download reginout that may help u
Posted on Aug 24, 2010
Khman
  • 180 Answers
SOURCE: DELL INSPIRON 1545 (Windows 7) My
Hi
It seems that the Hard Disk is disconnected from it's connectors
It needs to be fixed and installed correctly.
To do that, there are screws in the back, remove them and disconnect the hard disk, and reconnect, fix it correctly.
If it's difficult to you, go to technician to do that.
Please, Tell us your results.
Good Luck
Posted on May 20, 2011
HEPL !!!!
More than likely your hard drive just died. Bring it in to a pc fixit shop.
Jul 24, 2012 | Dell Computers & Internet
Internal hard disk drive not found To resolve this issue, try to reseat the drive. No bootable devices--strike F1 to retry boot, F2 for setup utility Press F5 to run onboard diagnostics.
it looks like your hard drive has crashed but before i confirm you need to try these steps first.1:remove the hard drive if its a SATA make sure the connectors on the drive and laptop are clean, if not clean it. if its an IDE check for any bent or broken pins.2: connect your hard drive to another pc or laptop using an external cable and if it is detected try and retrieve as much information from it as possible and format it with the quick format option deselected.3:if you dont have an external cable to connect it after you have physically cleaned the hard drive, mount it back in the laptop and check to see if it still gives the error. if it does run a windows installation setup from a disk and see if it recognises your hard drive. you can then format it from there and reinstall the operating system on it. 4: if non of the above methods dont work you should consider replacing your hard drive.
Feb 06, 2012 | Dell Latitude D630 Notebook
DELL INSPIRON 1545 (Windows 7) My laptop is displaying the message below when switched on: Internal hard disk drive not found. To resolve this issue, try to reseat the drive No bootable devices...
Hi
Good Luck
May 20, 2011 | Dell Inspiron 1545 Notebook
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
Aug 04, 2010 | Dell Inspiron 1525 Notebook
My laptop is a dell 6000 and it says there are no bootable devices
your hard drive has failed, on boot (dell splash screen) press f12 to bring up boot menu, choose diagnostics option, run this and it should confirm hard drive failure on dst short test (drive self test) and give an error code (e.g 2000 - 0142), trust me on this i am a dell field service engineer
Jan 14, 2010 | Dell Inspiron 1525 Notebook
Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Oct 27, 2009 | Dell Inspiron 1521 Laptop
Stop 0x000000f4
The error suggests that there is no bootable device available. Check if you are able to get to BIOS. Check for the hard drive . If hard drive is listed in BIOS, please run the diagnostics on the hard drive. If you get any error messages, then it could be an issue with the hard drive.
Sep 24, 2009 | Dell Inspiron XPS M140 Notebook
Computers & Internet Logo
262 people viewed this question
David Payne
David Payne
