Question about Sanyo DP50747 50 in. Plasma TV
So my tv has worked fine for about a year or so and then it stopped working, wont turn on so i left it alone and unplugged for awhile thinking i needed to get a new oe then a couple weeks has passed and i plugged it i and it turned on worked just fine for a couple days but i left it off for about a day and now when i try to turn it on I can hear a click click come from the power board and the green light on the board itself will start blinking twice then off blink twice then off but the screen still wont turn on.... Any suggestions? all the fuses are fine and the caps look okay I guess so im thinking new power board..
    Scholar:
  • 97 Answers
It most certainly a power supply issue. If the board is separate you might find one reasonable, but some are all-in-one boards and only a technician who knows how to repair the electronics will help you. most of these are bad capcitors
Posted on Oct 17, 2013
  • Judah Griner
    Judah Griner Oct 18, 2013
    Okay cool, I really just needed a second opinion before I went and tried replacing all the boards cause they are all seperate and to replace the power supply board would just take disconnecting a few clips and it pops right out and the new one pops in. So thanks rick I really appreciate it
  • Judah Griner
    Oh ad just in case do you think the a/c power cord could have anything to do with it burning out?
    President:
  • Sanyo Master
  • 749 Answers
I would not jump to conclusions just from that symptom, but I would agree that the power supply board is a strong candidate for this type of problem.
In reality it is also possible for almost any other board to be the source of the problem, probably the main board being the first candidate after the PSU.
On a side note, there are several different sub-versions of the DP50747 model, something that is NOT reflected in the fixya's model categories; the differences between the different versions can be from minor to significant.
Before getting your board you *need* to either look up the sub-version (called "chassis" on the label at the back of the TV) or, better yet, open up the TV and look up the power supply board markings in it.
Lastly, here's something that may help:
http://www.coppelltvrepair.com/search?Q=DP50747&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Posted on Mar 08, 2014
  • Joseph Hoffmann Mar 21, 2014
    Hi, As other guys have stated the power board is the problem.
    Bad caps are most likely. Take it to someone who can repair this.Unless you have some experience with electronic you can do it yourself.Good luck.
freetek
  • 5568 Answers
SOURCE: White screen only on Sanyo DP26648
Your reported symptoms are odd in that most failures are related to the primary power supply but that takes down both audio and video.
The backlight is obviously working (white screen) but it is no longer receiving any video information and this points to a failure of the logic (or the output of the power supply that services logic) used to control pixels on the screen.  Some screens have the majority of the control ICs actually mounted on the LCD assembly and because of very close pin distances used on dense ICs, they are often not replaceable by hand since they were installed by robotics.
I would first suspect (and hope for) the logic voltage output of the power supply to be the culprit.
If any of you posters have had a repair done and received any kind of a detailed report (you should), would you be kind enough to post it back as a comment to this original message?
Posted on Jan 16, 2009
  • 10 Answers
SOURCE: GREEN POWER LIGHT NO LIGHT ON SCREEN NO SOUND
I am a military spouse and our Sanyo 42 inch plasma tv just decided to die on Super Bowl Sunday 2009, and was only a few years old. We did everything we know to do: call the company, called the repair man, etc. There apparently isn't a solution to this that wouldn't cost more than the tv is worth. So I got an attorney to start a class action:
If you would like to be compensated for your TV, if it is the same model and you have the same problem (just abruptly stopped working) please contact me @
Danimimozi@gmail.com
Posted on Jun 24, 2009
SOURCE: TV blinks and then no picture at all
HOW DO YOU CHANGE A LAMP BULD IN A SONY HDTV. MODEL#KDF-E60A20
Posted on Oct 11, 2009
SOURCE: Green light blinks but no sound no picture
Power surge will knock out picture and sound if you don't have a power strip. Found out from Best Buys when purchasing another LCD TV. They have a warrenty against such problems.
Posted on Feb 12, 2010
jrweighing
  • 183 Answers
SOURCE: My new Sanyo HDTV LCD won't come on, although the on light is on.
If your Tv is in warranty or you have a cover plan, you need to return the Tv for repair or replacement.Your Tv sounds like it has a power supply fault.
Posted on Feb 28, 2010
Scepter 32". Received this for Christmas 2012. It's worked beautifully up until about a month ago. When you turn it on the blue light comes on but nothing happens. You can't turn it back off without...
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
It's not unusual for this type of electronics to only last a couple of years.
May 03, 2014 | Televison & Video
It randomly turns of by itself and sometimes doesn't turn back on for awhile. The last time it did it I unplugged it and left it alone for about a day or so. When i turned it on it worked a full day...
i had the same problem and still do ive owned mine since 2005 the people of RCA told me to leave the thing turned on as much as possible so i just turn the volume down and leave the tv on when i go some where( unless im going to be gone a couple of days) or go to bed
Apr 11, 2010 | RCA HD52W59 HDTV Projection Television
I replaced the lamp bulbs and the TV worked fine for awhile but shut off after about three days of use. I unplugged it and waited awhile to plug it back in the timer light blinked for awhile and then went...
While it is suspicious happening so soon after lamp replacement, your main power supply may have failed. In earlier sets, these were problems that eventually happened.
Feb 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
TV won't come on
I have a 32 inch tv was working great then went into standby mode and wont turn back on. I have unplugged and am waiting please help!!!!
May 18, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Battery problem or camera problem?
A new battery should help you to solve this problem.
Aug 07, 2007 | Casio Exilim EX-Z57 Digital Camera
TV wont turn on?
this product has a bunch of exotic semiconductors that only a tech could replace in my parleyance its called NECO
Dec 08, 2006 | RCA 27R410T 27" TV
Sanyo DP50747 50 in. Plasma TV Logo
155 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
