Question about Ricoh Office Equipment & Supplies
Replaced waste tank on ricoh aficio 615C but still getting same error that waste tank B is filled
munybuny
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
  • 126 Answers
SOURCE: where is waste toner bottle
waste toner bottle is just beside paper tray 1. its the left side small cover. open the front cover and open the screw from top and open the cover in front and pull the bottle out. if its hard then email me on ronils_singh@yahoo.com.au. i am a Ricoh tech. i will help you out.
Posted on Oct 01, 2010
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
I have a Ricoh Aficio GX5050N and I have cleaned out the waste ink tank but cannot reset the counter. the INK CU replace command does not appear to work.
cleaned tank ,reinstalled, same? read for hours?? , powered on printer with ink cu out slightly,ink cart door open, the prompts came up to replace the cu, then do you want to reset counter, hit enter, closed ink cart door, done ! ,, whewww !
hrdchgr69@aol.com
Sep 15, 2011 | Ricoh Aficio GX5050N Printer
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
After replacing the ink waste tank, I am still getting an error stating replace waste ink tank full on an Ricoh GX3000 all in one.
This may have to do with the method of replacement. Leave the printer on, remove the waste tank, clean the area (sensors may detect residual ink) replace the empty waste tank. If this doesn't work, there may be a chipset on the waste tank to indicate end of life. This is a way for the manufacturer to continue making a truckload of money from the end user. Generally the only way around this is to modify your printer to by-pass this part of the circuit (an electronic solution to replace the chipset). This method will most likely void your warrantee.
Aug 25, 2010 | Ricoh Aficio GX3000S multifunction Ink...
ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
I replaced the ink waste tank on my Ricoh GX3000 - then it asked for new yellow ink cartridge and I replaced that. Now I have an error code 990 and I can't get rid of it.
bonjour,
allume ton imprimante,puis retire toutes tes cartouches.
eteint l'imprimante.
rallume l'imprimante et remet les cartouches.
le code d'erreur 990 indique de l'air dans les tuyaux.
ça devrait marcher!
Oct 05, 2009 | Ricoh Aficio GX3000 InkJet Printer
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Probems with a waste ink tank on a Ricoh Africio MO C1500 sp
on the right hand side of the machine , open the door you will see a transfer belt unit pull it out,there have a plastic pan remove it dump the waste toner.
Dec 02, 2008 | Ricoh Aficio MP1600SPF Copier
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
32 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
