Question about RCA RS1285 CD Shelf System
Cd will not spin - RCA RS1285 CD Shelf System
CDP cx355 cd doesn't spin
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 13, 2015 | Audio Players & Recorders
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
Insignia cd player that reads no disc when it is turned on with a cd installed
Hello
Check whether the inserted CD spins inside your unit or not. If it spins, and the set does not recogonize the disc, the laser pickup assembly has the trouble and should be replaced with same type and number. If it does not spins, the sled motor, the motor that spins the disc, is faulty and should be replaced. OK.
Jul 02, 2011 | Insignia 75W DVD/CD/HD Radio Compact Shelf...
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
Cd player on my dell will not spin
check that power cable to rom is plugged in....if still no spin, then replace cd rom unit
Dec 29, 2009 | Computers & Internet
My cd player stopped spinning cambridge 88CD
Quite possibly is the motor if it is spinning on and off u need to clean lens or buy a new one!!!
Aug 20, 2009 | Audio Players & Recorders
Saying no rdy on cd player (Emerson)
make sure you have a cd and your tray spins when opened
Aug 11, 2009 | Emerson MS9700 CD Shelf System
Cd player on boombox not spinning properly.
Might be the laser but try lubbing the spindle motor 1st!
Mar 02, 2009 | Coby CX-CD248 Radio/Cassette/CD Boombox
PD-F505
try a lens cleaning cd,if this doesnt work is more than likely optic (laser) faulty as laser has to focus first before spinning disc.if it cannot focus disc will not spin..
May 15, 2007 | Pioneer PD-F505 CD Player
RCA RS1285 CD Shelf System Logo
24 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
