Question about Coffee Makers & Espresso Machines
The spring and black plastic piece came out of the water container in my Cookworks Signature Coffee Maker as I was cleaning it. I don't know how to get them back in place. I have tried every way I possibly can but obviously I'm doing something wrong. Can anyone help please? Theresa
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Hold the spring in retainer first with masking tape , then put the plastic in , then remove masking tape and twist the plastic 1/4 turn .
Posted on Nov 02, 2013
  • 4 Answers
SOURCE: Saeco Coffee maker container is leaking
OK, I finally called Saeco. There are about four rubber rings that you need to get. The one for the water resevoir is a big thick black ring and once you get it and look at the new and the old, you can see why it is leaking. Anyway, fixes it no problem.
The overflow in the drip tray? There are two rings in the back of the machine that will fix that problem. Problem? I got them, but haven't put it on there because it very hard to get in there.
Last one, the ring around the coffee puck maker (what do you call that part) It's the piston that catches the coffe and raises up to tamp it down, then holds it as the water goes through. ANyway, big ring around that. If you aren't getting a nice crema on top, that ring will cure that.
I saw get all four, replace them all at once and then descale the coffee maker and be done with it. You'll be working like new in a few hours or maintenance. For most of us, it's been like 3 years anyway, time to do it.
Lastly, when you call Saeco, (Pronounced I found our SA Yey Co) ask for the directions for cleaning out the grinder. Even has notes on how to get it back together with all the adjustments in the right spots.
The rep on the phone says she likes this model better than most fo the new ones.
Posted on Dec 10, 2008
invisiblejim
  • 7 Answers
SOURCE: I was trying to clean
I think the main problem with this machine is that the grounds fly all over inside when grinding and combine with the steam and hot water and eventually gum up the moving parts. This causes the latch for the filter basket to lose its grip sometimes and the door pops open during the brewing cycle...I was trying to take apart the slides to clean them out and made the mistake of removing the small screw underneath the left slide. Then the spring popped out and it took about an hour to get it back together, very frustrating. I ended up bending one end of the spring into a slight hook with a needle nose pliers so it would catch better on the "nub" that is connected to the side button. The best way I figured out to clean the slides so far is to blast them out with compressed air periodically for preventative maintenance. I use one of those cans normally used to dust off electronics and insert the straw into the slides.
Posted on Feb 18, 2009
SOURCE: bosch porsche 9110 drip coffee maker
mine just broke this morning! i just ordered the same part from appliancepartspros.com - the part number is AP2807555. It is currently backordered until 4/25/09 - hopefully I will get that and the other part I ordered. Hope this helps.
Posted on Apr 15, 2009
SOURCE: ESTRO VAPORE
I just took mine apart, and put it back together. Of the three holes for the screws, there are two smaller and one bigger hole. Align the larger hole on the filter and the base, and the tiny plastic bit and the spring go in to the larger, along with the hollow and larger screw.
Posted on Jul 19, 2009
s_crane
SOURCE: User manual for cookworks signature coffee maker
need instuction manual for cookwork signature expresso maker
Posted on Dec 07, 2012
Miele CVA5065 coffee machine- the manual states : "fill the big plastic container to the max level". What is the volume to the max level?
Filling The Water And Coffee Bean Containers - Miele CVA ...
www.manualslib.com > ... > Coffee Maker > PW 5065 > User manual
Miele CVA 5065 Manual Online: Filling The Water And Coffee Bean Containers. Thecoffee machine must be cleaned thoroughly (see ''Cleaning and care'') before you... ...up to the "Max." mark. A valve at the front of the water. container will ...
[PDF]Operating and installation instructions Built-in coffee ...
Nov 25, 2015 | Miele Coffee Makers & Espresso Machines
I lost my instructions to Cookworks Signature Juicer model no kp60pa. I don't know how to take out dirty pieces Juicer to clean, wash them???? Please, help. Elwira
Well, you won't find any solutions on this web site. It is just for advertising other products so don't waste your time searching.
Aug 31, 2011 | Microwave Ovens
Having a problem with the mix. In the disposed grind container I am getting a lot of water mixed in with the grinds. Tried to clean screen and a glass bead fell out. I am assuming this came out of the...
The glass bead is part of the pressure system. It goes under the long tapered spring. The bead goes in first, then the small end of the spring, then the Oring goes around the spring on the plastic part of the head. Then the manifold goes on with the L shaped tube going towards the handle side. Hold down the manifold when you puty the screws in.
water in the dredge drawer is a sign of a coarse grind. The finer the grind the less water in the dredge drawer. Don't go too fine or you will be cleaning the brew head a lot.
Nov 09, 2010 | Saeco Vienna SuperAutomatica Coffee...
I was cleaning the water tank and i accidently knocked out the spring, tiny black plastic stopper and the white rubber washer, please could you help me put it all back together again, hopefully this can be...
Hi!
I've got the same problem and I managed to solve it.
So you have to put the plastic stopper to the buttom of the water tank in way that the wider end is down. You must hang the spring on the plastic stoppers narrow end so it would be placed between the water tanks bottom and the plastic stopper. Then you have to place the rubber washer from inside the water tank on the plastic stoppers narrow end. So would look like the following: plastic stopper -> spring -> water tank -> rubber washer
Jul 08, 2010 | Gaggia Caffitaly K111 Coffee Maker
Sep 25, 2009 | Coffee Makers & Espresso Machines
Rubber O came out & has been lost. I need to replace the rubber
Most well stocked hardware stores will have a box containing a huge assortment of rubber O-rings for sale at about 10 cents apiece. They come in varying thickness and diameters. If you're not sure, you might buy several to try and still not spend a dollar. The same part from the manufacturer will set you back ten dollars. I have no clue what your "plastic piece" may be, but if it's broken off you'll need to buy a new basket.
Dec 27, 2008 | Kenmore KBC12 Coffee Maker
Cleaning light came on and lost manuel on how to clean it
1 part descaler 1 part water put that in our water container stsrt it up rince very good especialy if you use descaler . descaler is better than vinegar descaler melts the calcium vinegar remove calcium in little piece thanks for using fixya pierre
Feb 13, 2008 | West Bend 56860 10-Cup Coffee Maker
BUNN BX-B Coffee Maker Leaking
is it the water container that leaking the best thing to do is open it maybe is a loose pipe or dry pipe connected to water container and if it the water container use 5 or 1minute epoxy cheers
Jan 29, 2008 | Hamilton Beach BrewStation Deluxe 47474...
Filter basket retains water
it sounds like a restriction in the perk tubes have you cleaned I mean deep clean the unit??? It should be as any auto coffe maker should be clean deeply every three to six Months depending on how much you use it. How you do this is take 1/2 viniger in pot and fill to capacity.. Dump this into the unit and brew it through. Then ite recommended to rinse them by brewing three to 4 times with clkean water. now if this dosent work its probably behound feasability to repair
Mar 21, 2006 | Black & Decker Cafe Noir DCM1400 Coffee...
Coffee Makers & Espresso Machines Logo
75 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
