Question about Acer AL1715 Monitor
Is it possible to rotate the screen (acer al1715sm) from its base? (to srew on the wall) cause mine moves up and done, but gets stuck after a small bit..
    New Friend:
Find audio multimedia base like VG3P31 (Philips) std. 4 screw mount pedestal like photo below..move up/down, CW, right/left.is it possible to rotate the screen (acer - 659ae0f8-3ebc-40d3-ad3a-1dd9b380bafc.jpg
Posted on Nov 05, 2013
Remove stuck screw from crankcase coveron '83 Honda c110 motorcycle
Hi! if you don't have a hammer-screwdriver (what is the right name?) just use a puncher + hammer: on the side of the head first punch a small hole, so the tip of the puncher is well held on that spot/hole. Then carry on with the puncher a bit off-axis (of the screw), to cause the screw to rotate a bit to the left. Then carry on. Some WD40 can help too. I got some great results like that. Good luck!
Aug 17, 2014 | 2005 Honda Shadow Spirit 750
My lawn sprinkler a K-Rain Cyclematic Distributing Valve, gets stuck in between zones..it wont advance..any ideas ?
The internal disk-shaped rubber valve mechanism is failing to rotate. With the water shutoff (mine has no pressure when the controller is set to "off") remove the eight stainless screws on the top, tap it loose, and lift off. You'll see the black rubber disk I am talking about. Pull it out and use wet/dry sandpaper to smooth the inside wall of the aluminum housing it sits in. Mine builds up some roughness from corrosion, which drags on the disk and prevents its rotation.
Oct 04, 2011 | Nelson Sprinkler: Traveling Tractor
I have a Maytag Performa Washer...It will fill with water but will not move through the cycles...it simply sits full of water and you can hear a humming noise and a smell possibly like rubber. A friend...
sounds like either you have a stuck pulley or pump remove water with shop vac and tilt washer against wall get under washer remove belt spin small pulley by hand does the pump pulley move all directions freely if not something stuck in pump or is belt melted or worn out
Jan 27, 2011 | Washing Machines
Error message H03 appears when the player is turned on. It will not play the DVD.
PLEASE REMEMBER TO RATE/AWARD MY RESPONSE SO THAT I MAY KEEP HELPING THOSE IN NEED FREE. fixing code H03
is very simple but needs some courrage and small philips screw driver.
the problem arrise from the laser lamb which moves up and down the disk through a mechanical shaft
I do believe when we press the back space for long time it will take the laser lamb beyond its limit and get stuck at the end of the rotating shaft so the servo motor gets difficulty and resistance to get it back to tract
all you have to do is open the back of the 12 small screws" (THE AMOUNT OF SCREWS MAY DIFFER FROM A CASE BY CASE when you remove the back cover be carful not to damage the cables you will find the servo motor and laser lamb on one metal structure hanged to the body by three rubber suspensions remove the whole structre and turn it upside down slowly
move the small black rotating joints up or down you will notice the the mechanical shaft will start rotating and the laser lamb will start to move away from the servo motor relasing it from where it get stuck and it will work perfect after that
return the back cover and screw the 12 screws (AMOUNT OF SCREWS MAY DIFFER) and you are done
Jan 11, 2011 | Panasonic DVD-LS50 Portable DVD Player
Dear Sir, My name is Muhammad Farrukh from Saudi Arabi (El-ajou Group ) I have one Zebra Printer Model : Z4MPlus Error message is coming : HEAD OPEN although it is close. if it need to replace any...
it is possible that the sensor is far from the printhead, just move the small crone plate with the small sensor, down or up, moving close or far from the printhead. if didn't fix, move the red bits from the top of the printhead to the left or rigth side, making more pressure . if didn't work, move all the printhead mecanism dont or ul, (3 srews on the left and one srew unther the printhead, next to the sensor.
Jan 06, 2011 | Zebra Z4Mplus Label Printer
Ice maker stuck in crush mode.... Frigidair modle frs26r4cb3
Mine was too. under the tray there's a long rod with a spring attatched. that rotates. behind the tray the rod ends in a small opening with a lever in side that moves up & down. that lever failed on mine. now under the tray in the front there's a round thing that moves with the rod underneath that runs into that hole in the back. I just jury rigged mine with a spring to keep that plastic roundish thing in front & under, rotated all the way counter clockwise or all the way up & to the right. NOW AND THEN ICE WILL CRUSH BUT i NOW JUST MOVE THAT THING OVER AND I'M GOLDEN. Hope this helps signed ... "I'm just a carpenter."
Nov 06, 2009 | Frigidaire FRS26R4A Side by Side...
The screen moves from small to large and I don't
Its the "Zoom" Control located I think on the lower right of the screen; increase the size of the display to 100 %
Aug 12, 2009 | Acer Aspire One PC Notebook
When it tried to read a disk I get an error code ho3. the model is panasonic dvd-ls82
Fixing code H03 is very simple but needs some courrage and small philips screw driver.
The problem arrise from the laser lamb which moves up and down the disk through a mechanical shaft. I do believe when we press the back space for long time it will take the laser lamb beyond its limit and get stuck at the end of the rotating shaft so the servo motor gets difficulty and resistance to get it back to tract.
All you have to do is open the back of the DVD player " 12 small screws"
When you remove the back cover be carful not to damage the cables .
You will find the servo motor and laser lamb on one metal structure hanged to the body by three rubber suspensions.
Remove the whole structre and turn it upside down slowly .
Move the small black rotating joints up or down you will notice the the mechanical shaft will start rotating and the laser lamb will start to move away from the servo motor relasing it from where it get stuck.
And it will work perfect after that. Return the back cover and screw the 12 screws and you are done. Good Luck.
Apr 08, 2008 | Televison & Video
Data Cable cut on ACER AL1715sm
Hi, I have AL1716 so pretty the same - both cables (power and analog VGA cable) are inserted into sockets, probably your VGA cable can be screwed in - just unscrew it and go to nearest PC shop to buy new one. What a good cops you have !!
Oct 14, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 Monitor Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
