Question about Drills
I have a Ryobi lithium ion battery that will not function. The chargers shows a defective battery but when I press the "fuel gauge indicator" button it lights up green. I checked the voltage on the battery and it momentarily reads 19.## volts then reads nothing. I checked the individual cells and they all read 4.2 v Any suggestions? Bad circuit board?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Battery problem defending how old?
Posted on Nov 06, 2013
  • 384 Answers
SOURCE: I have RYOBI 4V Lithium-Ion Screwdriver and lost
Yes.
Posted on Sep 15, 2009
  • 2527 Answers
SOURCE: Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
Posted on Jan 16, 2011
  • 259 Answers
SOURCE: Is it possible to repair a defective lithium ion
Maybe there is something wrong with the charger itself. If you have a friend that has the same drill try to charge the battery on his charger.
Posted on Mar 19, 2011
SOURCE: my 18 volt Ryobi battery shows charged in charger
Some of batteries drain very quickly. Depends on how they are used.
Feel free to check Your Local battery Manufacturer for best prices for all different batteries. You name it and they have it or they can custom make a battery for you.
Thanks
Posted on Aug 15, 2012
H2_Brad
  • 425 Answers
SOURCE: Who rebuilds ryobi 18 volt li ion batteries
I have used Batteries Plus and had fine results. See if there is one near you.
Posted on Aug 23, 2012
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
Aug 23, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
My 18 volt Ryobi battery shows charged in charger (Green Light) But will not work in any of the power tools. I have three other Batteries that do work. Bought at Home depot on july 24 2011 Ryobi Two 18V...
Thanks
Oct 09, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I purchased a Ryobi drill with Lithium batteries (Large/with gauge, small without gauge) in June 2009. The large battery lasted about 3 months and started holding less and less charge (yellow, then red on...
Batteries must be completely dead before recharging or battery life is shortened.large battery is probably defective contact Ryobi to replace battery they while probably send you new batteries for free if you tell them you are going to stop buy their products.Tell them about both batteries they will probably replace both for no charge
Jun 12, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I bought the two pack Ryobi Lithium-Ino Batteries along with the six battery Ryobi One + Charger. When I use it on my P201 Ryobi 1/2 Drill and the drill encounters any type of a torque situation the...
I would not say they are not defected, but I think they are not getting fully charged. I have the same problem with my battery once I have used it all day and the red light comes on from the fuel gauge. I have the P104 battery. I would return your charger and try to charge them on the new one first. If you have the same trouble, then return the batteries for new ones.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Apr 01, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
New Ryobi 18v lithium battery goes dead after a couple of seconds. Is there any solution other than returning it?
No, just return it, for the money they should give you one that works. It is common to get a defective Ryobi 18v lithium battery. I've had 2 out of 7 purchased that wouldn't hold a charge. But when you get a good one they work awesome!
Jan 24, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Battery charges but is dead
The battery isn't any good. The charger is just going through it's regular steps. (I know how it is. I just bought two Ryobi 18 volt batteries for my Ryobi cordless drill, reciprocating saw, flashlight,
trim circular saw, combo set. $60 for two batteries)
Jul 15, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Drills Logo
66 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
