Question about Isuzu NQR Bolt. automatic transmission control cable. air intake
I have a 2002 Isuzu Rodeo automatic that will only move in reverse at high RPMs. It works fine in all other gears. I took it to AAMCO and they said that to fix the problem they would have to do a total rebuild for $3200. Can you fix just the reverse part of the transmission? Any other ideas on fixing the problem? FYI they did not open the transmission to make this determination they just put in into reverse.
    New Friend:
  • 15 Answers
Yes you need a rebuild 3200 is a little stiff. Look for a smaller shop or do you need there warranty
Posted on Jan 10, 2014
Why wont my isuzu rodeo stay in gear
there are only 3 issues here.
1 weak engine, , even 1st gear I have no engine power.
2: 1st revs normal but wont shift up.
3: the transmission slips. (flares) RPM goes nuts.
which one?
Jul 14, 2014 | 2001 Isuzu Rodeo
Automatic transmission
If your Vehicle will not move in reverse until you you reverse it up sound as thought your reverse pump in your trans has gone or getting ready to go out . It call worn out . So you will have to change the trans out for R&R trans it will run about $2000.00
Oct 08, 2013 | Isuzu Rodeo Cars & Trucks
I'm having transmission problems on my 2002 Isuzu rodeo first gear is really slow but as soon as it gets to second and up its ok.
If that is an automatic & if the fluid has not been
changed every 3 years since it was new,then it's
done,pull it & rebuild it
Sounds like it is slipping in first gear,the fluid should
smell bad as well
Sep 05, 2013 | 2002 Isuzu Rodeo
Reverse on 1994 Isuzu Trooper
run fault codes and look for a reverse solenoid /sensor fault.
Apr 25, 2013 | Cars & Trucks
When in gear and a/c is turned on, wants to stall
run the fault codes and check for problem idle control sensor
500 rpms are too slow for idle should be around 850 for automatic
also have the voltage regulator /alternator checked as the problem is not enough voltage ti run the car and the ac because the available voltage isn't high enough
Apr 06, 2017 | 1994 Isuzu Rodeo
Isuzu rodeo, RPM's shot up, pulled over, Problem with the Isuzu Rodeo 2002 Rodeo isuzu rodeo, RPM's shot up, pulled over, placed in park then shifted to drive, car would not move, shut off, car...
Isuzu rodeo, RPM's shot up, pulled over, Problem with the Isuzu Rodeo 2002 Rodeo isuzu rodeo, RPM's shot up, pulled over, placed in park then shifted to drive, car would not move, shut off, car would not restart
Jul 09, 2011 | 2002 Isuzu Rodeo
Transmission, not wanting to go in gear
After replacing a transmission on one Rodeo for that problem, I discovered there is a transmission control module located on top of the transmission on the driver's side. Two bolts disconnect it. Wipe off the old electric grease, and put on new electric grease. Reinstall the part. I have now driven 30,000 miles on this fix. Needless to say, I was very unhappy with AAMCO. If your rodeo starts having that problem, drive only in third gear until you can fix this part. Planetisuzoo is very detailed on this fix.
Dec 30, 2010 | 2002 Isuzu Rodeo
1996 Rodeo Isuzu - I put it in Winter Drive and now 1 rear wheel
Based on another similar problem and it was fixed driving backwards, that's exactly what I did. I drove the Rodeo backwards and then would stop and put it in gear and did this for 10 minutes until I worked the 4x4 gear loose and now all four wheels run. I must say, I created quite a sight driving backwards in a Wal-Green's parking lot for 10 minutes.
Jan 28, 2009 | 1996 Isuzu Rodeo
95 Rodeo...won't move...something is locked up
id look at the gear box first and then the transmission
Jan 08, 2009 | 1995 Isuzu Rodeo
Isuzu NQR Bolt. automatic transmission control cable. air intake Logo
59 people viewed this question
Top Isuzu Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Isuzu Air Tool and Compressor Expert? Answer questions, earn points and help others
