Question about Brother 4pk Non-oem Ink Cartridge For Lc985 Dcp-j315w Lc39
When printing 10 X 15 photos with DCP J315W I get a thin border in spite of selecting "No Border".
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • Brother Expert
  • 234 Answers
Check the size of the file that you are printing and if you have selected FIT on the paper size
Posted on Aug 01, 2014
How do I fix the absorber full on brother printer DCP-J315W?
go to service mode by pressing *2864 then appear on screen mentainance press 80.then find purge,then after you find press 2783.then exit by press 99.
Aug 04, 2016 | Brother DCP-J315W Inkjet Multifunction...
Unable init. 50 on my Brother DCP-J315w ...what should i do
Any failure to initialise, print, clean error report usually indicates the waste ink chamber is full and the purge count has maxed out. You can remove the waste ink chamber, clean and replace the pads and refit it but seriously time consuming and messy. You should try the purge count reset first (do google search) eg this one
http://ref.topictimes.com/videos/tech/how-to-reset-purge-counter-on-brother-dcp-j315w-printer-full-1NzJwuCpVOc.html
If that works, you can keep using it but should clean the waste chamber. Or save the hassle and just buy a new machine :-)
Jan 05, 2015 | Brother DCP-J315W Inkjet Multifunction...
When printing 10 X 15 photo I get a thin border in spite of selecting "No border".
paper needs to be fed through the machine and so needs a small border to grab the 1st bit and pull it through. you will always get a bleed unfortunately
Oct 17, 2013 | Brother DCP 115C All-In-One InkJet Printer
Print head alignment nozzle
Borderless print ?
Set custom page as exactly paper size. Set borderless expansion to max. Select appropriate paper media type.
Sep 29, 2013 | Epson Stylus 1400 InkJet Photo Printer
Cannot load template to Sony UP-CR10L, how can I copy the custom made tempalte to CR10L?
You need to copy the border you created in the border creater software to a border folder on you computer that you have created to store you borders in.There is a folder on the CD that came with the machine that
I would suggest you copy to your hardrive as this will need to then be copied to a compact flash card that is then installed in the expansion slot on the inside of the ribbon carrier door.If you save your new border to the folder on you hardive you can always back it up at anytime.If you
print different sizes you will need to create a border for each size of print. Once you have installed the card in the machine switch it on and
go to the print option screen and you will see the border ikon is not greyed out but now active simply select this option and the the border you require.Then it should print.
Sep 18, 2009 | Sony SnapLab UP-CR10L Digital Photo...
Can't find program for borderless printing
You need to really defining "Border-less Printing". Are you speaking of printing border-less photos? Or do you mean border-less documents.
Border less photos are usually set up in the printer's driver, providing that the printer's hardware allows this function. Some printers, especially older models, cannot print to the edge of a page by design.
Don
Aug 16, 2009 | Brother MFC 6490CW InkJet Printer
When printing a picture on a full A4 page for a broacher I get a thin white border. I need it borderless incase movement in the printer.
You must select borderless in the print options/preferences menu.
What program are you using to print and I may be able to help more.
Jun 19, 2009 | Epson Stylus C67 Photo Printer
Boarders and titles
A name and date is very simple you can go to the control panel- Tap twice on the top left of the welcome screen and enter your four digit code default is 9999 - Click on the ikon at the top of the screen relervant to text - You can then type a Company name, Date or Tel No: - select font colour size and position - I would suggest white - You then click on
the add text button and it will be on all prints until you change it or switch it off - We put our Name, Tel No and a number to designate which printer it is as we have five of them and if we have a problem I know which one needs fixing.As to adding a company logo and date
in the borders section you would first need to create a border design
in photoshop or other editing program import that into the border creating software that came with the machine then save this to a borders folder on you computer - Then if you have a compact flash card in the expansion slot on the inside of the ribbon carrier door remove it
and add your new border to the borders folder on the card and replace it in the machine. If you havn't then copy the border directory from the CD
supplied with the machine to you hardrive add you new border to this folder then copy it to your new compact flash card - Place this in the expansion slot in the side of the machine as above.When you now
switch the machine on and enter the print mode select the border ikon and you should see all your borders - Select the one you require and print - If you print different sizes you will need to create a border for each size - You can also go to the control panel and set the machine to add a border every time it prints but I have never needed to do that but
it will but in the owners manual and won't be to difficult I assume.
Jun 11, 2009 | Sony SnapLab UP-CR10L Digital Photo...
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
Brother 4pk Non-oem Ink Cartridge For Lc985 Dcp-j315w Lc39 Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
