Question about Dishwashers
Maytag dishwasher model MDBTT53AWW2 wont drain completely in normal cycle. I time drain cycle in normal cycle and it took 45 sec. in cancel cycle it run 2 mins. I replaced the pump and check the flapper and have the same problem.
    Master:
  • 492 Answers
Sometimes the machines get out of cycle and you have to remove power from the board to rest the electronics. After a while the code on the board gets corrupted and you need to reset. Try uplugging for 30 minutes to clear the board of power.
Posted on Oct 17, 2013
4 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
SOURCE: Dishwasher not draining water
I had the same problem....removed hoses, checked for cloggs the hole nine yards.....Inside of the unit towards the back in the bottom is a filter cover and in the middle is a valve that you just screw out. It has a rubber stopper that overtime breaks down....I was able to pick up the part locally for about $17CDN, replaced the part and the unit drains properly now.....now I have an issue with no power
Posted on Jun 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Only thing the dishwasher will do is the cancel drain for 2 min.
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Sep 17, 2009
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Service number kuds301xbl2
    I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
    Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
    Kenmore 665 Dishwasher
    Sound like you have a bad control console, which will need to be replaced.
    Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
    DISHWASHER was locked now unlocked but won't run. Goes to drain/Cancel when you push the Normal Cycles
    Wondering how you unlocked the dishwasher. Normally you would have pressed Heat Dry for about 4 secs.
    I don't this action would have caused the problem. For dishwasher to run you need the door lock switch to operate. If door is not closed it will go to Cancel.
    Check item 12 in this diagram.
    Oct 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
    Blinking "Normal" light on a Maytag model
    Hi
    Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
    Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
    Hope this helps... Please post back if you need more information.
    Daniel
    May 19, 2011 | Maytag Dishwasher
    Washing cycle wont complete
    I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
    Dec 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
    Hi
    Thanks
    Rylee
    Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
    Dishwashers Logo
    71 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
