Problem for Craftsman Air Compressors
Generic problem for all Craftsman Air Compressors
I have a craftsman 3.5HP 30 Gal com...
I have a craftsman 3.5HP 30 Gal compressor (Model 919.152911). It only builds up to 30 psi. It does not go any higher. What could be the problem.
Rob
Comments:
Apr 25, 2009
- Thank you. I will check into these items.
Best Solution
posted on Apr 25, 2009
Rank: Guru
Rating: 85%, 30 votes
Unless your machine is worn out----it's probably the pressure switch:
A: needs adjustment
B: needs to be replaced
XYZ: head gasket leak,broken line, other air leaks?
Was this helpful?1 person thought this was helpful
Popular Solutions for Air Compressors
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
2 Solutions
Questions and Unsolved Problems for Air Compressors
how to wire a kobalt 60 gal vertical 208-240 to breaker panel
I'm trying to renove an ingersoll compressor t30 3"&1-3"/4 x2-3"/4 model 234....
(More)
I'm trying to renove an ingersoll compressor t30 3"&1-3"/4 x2-3"/4 model 234. The serial number is 8802263. I have ordered a seal kit, valve finger for the full unit but some seals do not fit one cylinder head (the "small cylinder" => is there different T30 models? I received a plate with 2 valves on it but this cylinder use 2 separates valves... Do you know where I can find the parts and service manual for this compressor ? Regards, Daniel
How many watts does compressor C2005 Type 3 have? I need to connect it to a mobile power inverter...
(More)
How many watts does compressor C2005 Type 3 have? I need to connect it to a mobile power inverter 750 watt DC to AC & USB power inverter. Converts 12V DC Power to 110V AC Household Electrical Power & 5V USB
Bought Northern Tool floor display model 123005 1.6 gal electric air compressor - store did not have...
(More)
Bought Northern Tool floor display model 123005 1.6 gal electric air compressor - store did not have owmer's manual. Expected to be able to find it online, but apparently not available. Any help would be appreciated, while the store continues looking for a manual.
need a new clutch plate for a holman compressor made around 1960 with a fordson major 4cyl engine...
(More)
need a new clutch plate for a holman compressor made around 1960 with a fordson major 4cyl engine serial number R 55 100
