Question about Lefroy Brooks BELFAST SINK SLOTTED WASTE - LB1384-NK - Silver Nickel
Belfast sink (old) chipped how to repair it - Lefroy Brooks BELFAST SINK SLOTTED WASTE - LB1384-NK - Silver Nickel
3 Suggested Answers
Obertelli
  • 3006 Answers
SOURCE: belfast sink repair company in ireland?
Sorry to disappoint you, but unlike steel or cast iron ceramic sinks cannot be re-enamelled. To do so someone would have to grind off the remaining enamel and then reapply and re-fire the sink: not only would this be very laboiur intensive but the sink would be unlikely to survive the mechanical and heat processes involved.
If you can't live with your crazed or cracked enamel then buy a replacement sink. They're still manufactured as there is a demand for them.
Posted on Jul 26, 2009
valuoils
  • 6 Answers
There is a company in Ireland that provides good quality oil at a very reasonable price and does such repairing as well e.g. Boiler Servicing, heating oil etc.
www.valueoils.com/
Posted on Jan 30, 2015
My Swanstone sink is sixteen years old and still in very good condition except for a small chip. The sink is a cream color with black and white specks. Is there any way to repair the sink?
You should be able to have a competent repair or restoration specialist from a reputable granite or marble fabrication shop come to your home and fix the problem. If it is a very small chip (less than an eighth of an inch around, my first try would be super glue. Keep in mind the fill will be fairly clear in color, which may match the dark specks, if not use an indelible marker after you smooth the glue to color it black. Use the gel type super glue if it is on a vertical portion of the sink, otherwise use a thinner variety. Clean the chip with sop and water, let it dry then use rubbing alcohol to remove any grease or oil residue. Use a masking type tape to isolate the chip so you have less work once the glue dries. Fill the chip and once the glue is dry, use a single edge razor (Use extreme caution, razors are by nature sharp) to gently scrape, not cut the glue flush to the sink surface. The manufacturers of these sinks claims they are difficult to scratch, but pay attention to your pressure or you might create scratches on the sink itself. Hold the blade perpendicular to the surface of the sink and take your time scraping the dried glue down changing to a fresh blade often. If the chip is in a radius area of the sink, you will have to be a bit more creative and probably use steel wool to remove the excess dried glue. I would start with #000 and see how that works, maybe using #00 to start the process and finish with #000 or #0000 steel wool to match the finish of your sink. If your chip is larger than an eighth of an inch around, I would recommend hiring a repair and restoration specialist from a competent granite fabrication shop to make a color matched epoxy to fill the blemish.
If you have any questions, feel free to contact me, Brandon Wiese - Brandon@StoneRepairman.com - http://www.StoneRepairman.com
Mar 25, 2011 | Swanstone KSDB-3322 Double Bowl Kitchen...
I'm in the North York - Toronto area, I have a blanco double compartment sink, black, it's approximately 15 years old and it has several chips in the enamel or porecelain. Is there someone who can repair...
If this is a SILGRANIT sink you will need to contact Blanco to find this out they do not reveal the material used in this sink and they may be able to help. This is the web site for Canada.
http://www.blancocanada.com/
Mar 14, 2011 | Blanco Home
FITTING A BASIN
I am guessing you have the square one then. You need to fit your waste as normal, Send the waste through a hole in the surface you are placing the sink on and make your connections underneath. I use plumbers mait as a sealant when tightening the outlet. You then need to think about your taps. Since they are totally separate from the sink you can use what you want. Most people would use a monobloc riser though, secured to whatever surface you are laying the sink on.
You don't say how much you need to know about connections / plumbing etc. Please ask again if you are stuck with these.
Oct 20, 2009 | Home
Very faint surface crack has appeared on base of my new enamel sink is it repairable??
If the crack is merely just a surface scratch and has NO depth to it. Then yes you can fix it and will never be able to tell a scratch was there before.
Most Home repairs store, i.e. Home Depot, Menards, Lowes carry scratch remover products. There might be a special kind specifically for enamel, make sure to check the package. The instructions are very straight forwards. Should not have any problems.
If it is a Crack, there is also like a bondo type product at the same stores that will fix it too...That takes a bit more technique to make sure its smooth and blends in with the rest but either way make sure you read labels and follow instructions.
I hope this Helps...Thanks for using FixYa.com
Aug 10, 2009 | Lefroy Brooks BELFAST SINK SLOTTED WASTE -...
Im looking for the code to ring an irish mobile in africa
The code for ringing Africa, is 0022, so, say you were a Belfast to Belfast for example it's 028-417-*****, but Belfast to Africa is 022-28-417*****. I hope this clarifies the situation. Regards
Dave
Jul 23, 2009 | Cell Phones
Belfast sink repair company in ireland?
Mar 06, 2009 | Lefroy Brooks BELFAST SINK SLOTTED WASTE -...
Repair chip
what you can do is buy a small tube of clear silicone .Dry off the chipped spot completely and apply a very small amount to the hole.make sure to wipe excess silicone asap .let dry for 2 hours and tou should be good to go.
Feb 02, 2009 | Vessel Island Glass Sink
K8S-LA mobo heat sink fell off.
That is the 'Northbridge' chip that provides the I/O interfacing for the main chip. The heat sink is normally held on with glue as you surmised, and should be re-done with a thermal conductive glue. The glue (a silver filled epoxy) is available from MCM electronics or from Mouser. Be sure to thoroughly clean the chip and heat sink before re-gluing.
Sep 01, 2008 | ASUS K8S-MX SIS 760GX CHIPSET SERIAL...
Dropped camera
No repair for this beast  only replacement
Check Panasonic  Support -  I think you will find this is the case
Oct 21, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
Convergence chip replacement. Part #STK-392-150
Hi.
You will need desoldering braid or wick to remove the old solder from legs of chips, Ensure no solder is sticking any of the legs to the pcb.
Once done remove screws or clip holding chip to heat sink & remove the chip. If chip is stuck to heat grip it with pliers & work it loose then remove.
Remember to put new heat sink compound on the backs of the new chips when fitting.
Oct 11, 2007 | Televison & Video
Lefroy Brooks BELFAST SINK SLOTTED WASTE - LB1384-NK - Silver Nickel Logo
27 people viewed this question
Top Lefroy Brooks Home Experts
Donni Steen
Tom Chichester
Are you a Lefroy Brooks Home Expert? Answer questions, earn points and help others
