Question about Ingersoll Rand Co. G5h/200501 Generator W/ Honda Gx270 9.0hp Engine
Where can i find the the codes for the hour meter on the display panel for 2005 Ingersoll Rand Model # BGE 7H
SOURCE: ingersoll 261 problem
that tool is under warrenty whoever u bought it from should have it fixed. did u try to adjust the air flow on your forard and reverse by turning the nob right or left has numbers on it hold the trigger turn the nob i see what it does i rebuilt many a 261
Posted on Feb 21, 2009
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
dontbother10
  • 2220 Answers
SOURCE: The oil fill plug broke on my Ingersoll Rand R 242-5n
Remove it and try a NAPA auto parts store. If they can't help I'd try Graingers.
Lou
Posted on Sep 02, 2009
compman66
  • 169 Answers
SOURCE: The compressor starts and stops after a short
More than likely it is a problem with the inlet control, commonly I have found wear in the throttle linkage can cause this or a faulty sump pressure sensor that is out of calibration.
Posted on Mar 07, 2010
  • 14 Answers
SOURCE: owners manual
Get on E-Bay and type in a company by the name of "Industrial_ Manuals". They're a real good source for air compressor manuals. John
Posted on Aug 30, 2010
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Where may I purchase or download a complte repair manual for the Ingersoll Rand model # 2475N7.5? Thank you in advance, Gary
I would suggest contacting a local Ingersoll-Rand air center, a lot of times they can make you a copy for little or no charge
Dec 28, 2009 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Ingersoll Rand Co. G5h/200501 Generator W/ Honda Gx270 9.0hp Engine Logo
14 people viewed this question
Top Ingersoll Rand Electrical Supplies Experts
cwradio73
Tom Chichester
Rhonda Webster
Rhonda Webster
Are you an Ingersoll Rand Electrical Supply Expert? Answer questions, earn points and help others
