Question about Panasonic KX-T7633 Corded Phone
How do you forward call to another specific line if main line is busy?
  • 2,113 Answers
Http://www.ask-tsc.com/pdf/KX-T76xx.pdf
Posted on Oct 17, 2013
How to transfer main phone number to cell number
If the featured is enabled at the phone company, grab the main line, enter call forward code (maybe *72), get stutter tone, dial your cell number, hang up. In the morning cancel forwarding, access main line, dial cancel code ( maybe *73), hang up.
Apr 08, 2014 | AT&T 922 Corded Phone
I have put a main greeting on my Norstar M7310 phone for all 5 incoming lines, however one of our incoming lines has grabbed a personal message form another extension and callers get that personal message...
You need to know what extension is causing the forward directly to voice mail. Chances are that this extension has ringing lines programmed to it and the forward on busy is to voice mail. ANY PHONE THAT HAS RINGING LINES SHOULD NOT BE SET TO FORWARD ON BUSY. If they happen to be on the phone when a call comes in it will go straight to their personal mailbox.
Aug 09, 2013 | NorStar M7310 Phone
How do I program the line redirection feature
If you switched phone companies and the feature stopped working you probably had Call Forward Busy/No Answer from AT&T. If you use the call forwarding in the phone it will use two phone lines for the entire length of the call. Call Comcast and have them add Call Forward Busy/No Answer and tell them the number you would like your calls forwarded to and the ring cycle (the number of rings on no answer).
Mar 05, 2010 | Nortel T7316E 2-Line Corded Phone
Hello I have a KX t7730 with 4 lines installed in it. the problem is that if person X phones and i am on the line speaking with person Y, than person X go's into voice mail instead of being "dragged " to a...
My office phone is set to Call Forward No Answer to Voice Mail.
I'm guessing that you are learning the difference between the TA series and the TAW or TDA series. Call waiting is programmed from a CW code dialed into the intercom (ie 7311 or *7311) and call forwarding to VM is programmed by a 71x or 710x or *710x command. In a TD TDA or TAW system, you get CF BUSY, CF NO ANSWER, or CF busy/NA.
In a TA you only get CF ALL, or CF Busy/NA.
So, if someone rings your phone while it's busy, there is no indication, just an immediate forward if that feature is set.
Carl
Dec 07, 2009 | Panasonic KX-T7730 Corded Phone
How do you take out voicemail from the phone so call forwarding can be processed?
I'm not sure that you are phrasing the question correctly. How can I bypass the voice mail box would be a better explanation.
If you take out the voice mail box it will go to the main greeting. Call forwarding to voice mail is call forwarding being processed. Is there somewhere else you would like it to forward to?
If you are just trying to delete your mailbox then you need to know your system manager info. If you do email me at IsaiahJ1980@gmail.com and I can help you further.
Call Forwarding Options:
From Port 1
Find port 01 or Tel 01 by pressing feature 4 from the lowest extension # in your system. Once you have found port 01 dial either of the following:
Call Forward Busy No Answer
Speaker 45, enter the extension you want to forward i.e 103, enter the destination, another extension perhaps 107 and speaker.
Call Forward Busy No Answer to an outside #
Speaker 45, enter the extension you want to forward i.e 103, press 9 and enter the destination phone # and speaker.
To Cancel Call Forward BNA
From port 1: Speaker 46 and the extension #
Call Forward All
Speaker 47, 103, enter the destination extension 107 and speaker.
(You will notice the Feature light flashing after this operation)
Call Forward All to an outside line
Speaker 47, 103, 9, enter the destination phone # and speaker.
To Cancel Call Forward All
From port 1: Speaker 48 and the extension #
Nov 13, 2009 | NEC Dterm DTP 16D-1 Corded Phone
AVAYA PARTNER ACS PHONE SYSTEM
Yes it can. Depending on the type of voice mail attached to your system you can both have the lines answered with a seperate main greeting (partner messaging can do this) or answered by a seperate mailbox (all partner voice mails).
Oct 06, 2009 | Lands Phones
2 lines comming in, Busy signal on main line when used
You need to call your provider to make the lines hunt. For a manual, you can try www.telemanuals.com
Jun 22, 2009 | Panasonic KXT 61610 R3 Key Service Unit...
How do I forward call on my blackberry?
Open BlackBerry Call Forwarding Options
To access your BlackBerry call forwarding options screen, click the green Send key and then open the menu options by clicking the BlackBerry Menu key. Scroll down and select Options.
You'll then be presented with a list of your BlackBerry's Phone Options, which include Call Forwarding. Click on this option and wait a few seconds for the call forwarding screen to populate.
Enter a New BlackBerry Call Forwarding Phone Number
Before you can forward incoming calls via BlackBerry, you first need to enter the number you want calls to be forwarded to.
On the main Call Forwarding options screen, click your BlackBerry Menu key and choose New Number. A dialogue box will then appear asking for the number to which your calls will be forwarded. Type in the 10 digits and click the trackball to save the number.
If you mistyped the new call forwarding number and you need to correct it you can click the BlackBerry Menu key on the main call forwarding screen, choose Edit Number, scroll to the number you wish to modify, click the trackball again and choose Edit from the available options. From there, you can make your desired corrections. To save the changes, simply click the trackball one more time. You'll then be returned to the Edit Forwarding Numbers screen. You can reach the main Call Forwarding option screen by clicking the BlackBerry Escape key once.
Enable BlackBerry Call Forwarding, Tweak Settings
On the main BlackBerry Call Forwarding screen, you have two options for call forwarding: 1) Forward All CallsForward Unanswered Calls. Below the latter option, you have three more choices: A) If Busy; B) If No Reply; and C) If Not Reachable.
By default, your device is set to Forward Unanswered Calls to your carrier's voice mail box in all instances.
BlackBerry Forward Unanswered Call Options
Forwarding every call that comes in to your device is simple; you just fill in the circle next to Forward All Calls and then specify the number to which you wish to direct calls from the corresponding drop-down menu. To save any changes you make, click the BlackBerry Escape key and confirm the changes when prompted.
Forwarding calls in specific situations is a bit different, but it's no more difficult. The first thing you want to do is ensure that the circle next to Forward Unanswered Calls is filled in. (Again, this circle will be filled by default unless you modified your settings.)
To forward only the calls that come in while you're already on the line, click on the If Busy option to open the drop-down menu and then choose the number to which you want to forward your BlackBerry calls. If that's the only call forwarding option you wish to modify, click the BlackBerry Escape key and confirm the change when prompted.
If you want to forward calls that come in while you're, say, in another room and away from the phone, change the number associated with the If No Reply option and save your changes.
If you want to receive calls when your BlackBerry is turned off or you're otherwise unreachable, modify the number settings next to the If Not Reachable option and again save your changes.
When BlackBerry call forwarding is enabled, you'll see a small icon, which looks very much like the missed call icon, appear on your BlackBerry home screen.
Finally, if you wish to return to your device's default settings, simply fill in the circle next to the Forward Unanswered Calls option and set the number for all three options (If Busy, If No Reply and If Not Reachable) to your wireless carrier's voice mail digits.
May 11, 2009 | Google Android
Kxtd816 how to do rollover or call forwarding line busy
Roll over or hunt group is handled by carrier
Mar 18, 2009 | Lands Phones
NEC phone system - Forwarding incoming call gets busy signal
please call the engineer from which you have purchased the EPBAX system to congiure the same. It happens if something is wrong in line card at the exchange or the extentions are not configured properly with the Key Telephone System.
Apr 18, 2008 | Lands Phones
Panasonic KX-T7633 Corded Phone Logo
37 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
