Question about ChoiceMedUSA OxyWatch Talking Fingertip Pulse Oximeter
[probe off] appears on my pulse oximeter..Model c9223..How can I make it work agaain
How do I get the pedometer to work on this unit?
Hold the pwr button for over 2 secs. to change modes. Tap to stop on first rt. arrow. (R resets to zero)--otherwise, tap to start and note blue arrow under "reset arrow). Start walking. Often it appears not to work but be patient. It will add all steps and/or jerks. When display goes blank, hit pwr. button momentarily for total "steps." It may be two steps off your count at times, but that matters not..
Sep 14, 2014 | CHOICEMMED OxyWatch CF309 Pulse Oximeter
I received a defective Pulse Oximeter
Did you check with the manufactorer? Most of the time they will exchange it for you.
Sep 10, 2014 | Contec Finger Pulse Oximeter CMS50-DL
What exactly is a pulse oximeter?
A pulse oximeter is a medical device that indirectly monitors the oxygen saturation of a patient's blood (as opposed to measuring oxygen saturation directly through a blood sample) and changes in blood volume in the skin, producing a photoplethysmogram.
Jan 30, 2013 | Health & Beauty
User manual oxywatch c9223
A box appeared in the upper right hand corner of the monitor. What does this mean?
Jun 08, 2012 | CHOICEMMED Pulse Oximeter Oxywatch...
My mother has a Digit Pulse Oxymeter and I was wondering how one knows if the %oxygen is reading correctly. Lately all her readings are always 97%. Very little variation.
The normal oxygen saturation in the body read by the any pulse oximeter whether it is portable or built in type is 95%-100%. If ***********'s oxygen reading as you have said is 97% definitely it is within the normal range. You can also check and make sure that your oximeter is working by placing the oximeter to your finger. If the pulse read by the oximeter is the same with your heartbeat it means that is working alright and the oxygen reading would fall between 95-100%. I hope my answers will help you.
Aug 26, 2010 | Probasics Digit-Ox Finger Pulse Oximeter
I need a Battery SPO Medical 903036 Mate Pulse
I am doing the same thing. Found the 903036 on Amazon, and scrolled down to "Frequently Bought Together" and found a lithium battery. Am thinking that is the one. http://www.amazon.com/SPO-Medical-903036-Check-Oximeter/dp/B000BQKH9W
Oct 08, 2009 | NRS SPO Medical 903036 Check Mate Pulse...
No reading for the blood oxygen level
OK - I had the exact same problem. I cleaned the inside of the oximeter with a cotton swab and denatured alcohol. Then tried it. It did not work. Darn. But I tried it an hour later, and suddenly, it started to work perfectly. I do not know what went wrong, and why it did not work immediately after cleaning. Maybe it was still damp from the alcohol? Unlikely, but I cannot figure out anything else. Anyway, try that and see if it solves the problem for you, and if the oximeter does not work for the first hour or so after cleaning, don't give up on it. Good luck.
Feb 05, 2009 | NRS SPO Medical 903036 Check Mate Pulse...
ChoiceMedUSA OxyWatch Talking Fingertip Pulse Oximeter Logo
569 people viewed this question
Top ChoiceMedUSA Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a ChoiceMedUSA Health and Beauty Expert? Answer questions, earn points and help others
