Jvc turntable al e31 - Audio Players & Recorders
djproaudio
  • 515 Answers
SOURCE: JVC AL-E300 Turntable
More than likely your motor might be bad. There is nothing else that controls the speed. Are you sure you purchased the correct size belt? Turn on the unit, without connecting the belt, and touch the motor shaft, and see if it fluctuates. You can also just get a marker, and marker a point on the motor shaft. When you turn it on, it will act as a visual indication as to it's speed.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Posted on Aug 08, 2008
smarthome2
  • 1114 Answers
SOURCE: What replacement stylus do I need for JVC
www.needlefinder.net If they can't get it, it's not made. Hope this helps
Posted on Jul 26, 2009
SOURCE: JVC AL-E300BK manual
Hello, I have the same problem as you, did you find the good adapter? Thks!
Posted on Jun 30, 2010
STYLUSCITY
  • 271 Answers
SOURCE: need to replace the belt on my JVC AL-A95
To replacea turntable drive belt.Copyright.. Styluscity.com, JohnHarrison. Nov 2011Before starting any work on yourturntable disconnect it from the mains power supply.Remove the stylus or completeheadshell to prevent any accidental stylus damage.1. Remove the rubber platter mat toexpose the platter.
2. Put your thumb and forefinger through the two round holes either side of thecentre spindle and lift the platter off. You may need to give the centrespindle a light tap (whilst applying upward pressure) with a screwdriver handleor some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcoholswab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flatwithout any twists.
5. Flip platter over the right way up. Acorrect fitting belt will stay put and an over belt will fall off.
6. You will see 1 or 2 largerectangle or square shaped cut outs in the platter near to the outer edge. Throughone pinch up the belt and slip a finger or belt hook between the platter pulleyand the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter backinto position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotationto ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correctoperation.
MUSIC IS LIFE, LIVE IT LOUD.Styluscity.com cansupply replacement drive belts for all turntables
Posted on Nov 03, 2011
SOURCE: JVC auto return turntABLE - mODEL al-a95bk
when you said "no sound enough to enjoy listening" did you mean that you could hear something coming thru the speakers, but it isn't loud enough? if so, you may be plugging the turntable into a "ceramic" phono input on your stereo. it may be that your stereo doesn't have a pre-amplifier on the phono inputs. Ceramic tonearm cartridges (the part that holds the stylus - which you may call the needle) have enough output level to drive an amplifier. if your cartridge is magnetic, the output is very low compared o the ceramic. the trade off is that magnetic cartridges have a much wider dynamic range than the ceramic, and when properly pre-amplified, sound MUCH better than a ceramic unit. you can probably find a separate pre-amp at radio shack (i know they sold them several years ago). you plug the turntable into the inputs of the pre-amp, then plug the pre-amps output into your stereo. hope this helps.
Posted on May 26, 2012
What external power cable/adapter do I need to power my JVC AL-E31 turntable. Any links or specifications would be greatly appreciated.
Are you still in need for help answering this question or have you sorted it out? I'd be happy to suggest some things :)
Dec 25, 2015 | JVC Audio Players & Recorders
Model AL-E31. What external power supply/mains does it require?
I can't find much about this model's power supply except that it's a 12 volt model.
If you look on Google there is a site offering the service manual, which will tell you more, but you might have to join to see it.
Dec 21, 2015 | JVC Audio Players & Recorders
Hi, I have a JVC AL-E11BK turntable with no power supply. Anyone know where I caj buy one? Thanks.
There are some sellers on E-bay selling JVC turntable power supplies. You could try them.
Sep 10, 2015 | JVC Audio Players & Recorders
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
Jul 18, 2009 | JVC Audio Players & Recorders
Speed switch doesn't work
hi, maybe you hve to replace the tack switch of your turntable even thougr you switch but the contactss maybe not in the connection,,
Apr 09, 2009 | JVC AL A158BK Turntable
How do you reinstall drive belt for JVC AL A155 model turntable?
http://www.archive.org/details/Turntable_Belt_Installation
archive.org above has a video about how to do it. The general method shown applies to just about any turntable including your JVC
Feb 10, 2009 | JVC AL A158BK Turntable
 Grubhead
Grubhead
