Question about Cell Phones
Friden alcatel letter opener model 5001
I'm looking for parts for our FridenAlcatel electric letter opener Model 5001....especially the belt that turns the feed rollers and the belt that turns the blade roller.
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
frcs68
  • 1605 Answers
SOURCE: Broken paper feed roller
you cn the roller from the link below:
http://www.precisionroller.com/manufacturers/hp-photosmart-c5280.html
Posted on Jan 27, 2009
Lightbearer
SOURCE: Samsung ML2010 laser printer paper feed roller belt
I just fought this same battle and have emerged victorious! The roller cam that the black rubber belt fits around is kind of "C" shaped in cross-section. The roller has left and right hinge-pins on one end of the "C" and snaps on the other. Looking at either side of the casing that the roller mounts in, you will see the end of the hinge-pin and a typical sqeeze clip like those often found on bigger laser printer rollers. I'm sure this was designed so that you should be able to sqeeze the left and right clips simultaneously which should release the snap end of the "C" and allow it to hinge out away from the casing. Unfortunately, it appears that the designer's good intentions were never tested. If your roller is like mine, it does not freely release by just sqeezing the clips. It was a bit awkward but while squeezing one of the clips, I used the tip of a small screw driver to pry loose the snap on that side. The trick is to hold that snap out away from it's seated position while you perform the same procedure on the other side. With both sides pryed away from their seated position you should be able to hinge the roller with black rubber belt away from it's case and remove it. In lieu of buying a replacement belt I simply rotated the existing one to expose the unused part and snapped it back in place. Voila!
Posted on Feb 20, 2009
  • 5 Answers
SOURCE: wire doesn't feed
Either the trigger mechanism in the gun is bad, the servo that turns the feed wheel is bad, or you have too much tension on the adjustable tensioner knob. Take the wire out of the feed wheel, plug unit in and see if you can get the wheel to turn. If not, it is the trigger or the servo. If it turns, the tensioner was too tight.
Posted on Jul 25, 2009
Testimonial: "Haven't checked out your answer to my problem yet, but I will. I'am very happy about getting a response, others sites never answered back. thanks"
SOURCE: canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
Posted on Apr 04, 2010
Can not open dvd drawer.
Sometimes drawer failure is due to dirt and debris but it also is possible that the mechanism has failed, especially if yours is an older player (5 yrs +).
May 26, 2014 | Televison & Video
Dryer struggling to turn and making noise.
first off send the brand name and model number off of the dryer open the door and look around the opening where you put the clothes in and you'll see the model number.there is only one belt,you could have a bad roller,or a bad belt pulley or something in the blower wheel from running the dryer with the lint filter out,something can go down where the filter goes and get into the blower but the only way to tell is by getting in there,if you need help send info or go on utube and put in your model and brand name,there's tons of videos out there on taking apart dryers.
Feb 07, 2018 | LG Tromm Electric Dryer
Upside down letter F and #5
does it look like this? t5 or ts could be a thermistor code.if you changed out the thermistor you most likely have a bad computer board.there should be a tech sheet in the machine usually in the top console. here's something that might help http://mikemerrittmotors.yuku.com/topic/2255 the machine doesn't run is that correct?i would check the obvious things,open the door and push in on the door switch and make sure that's working correctly,it should click when you push it in,there's a switch on the belt pulley,if the belt broke the dryer won't start,then check the thermal fuse,the thermistor and if they all check good then you have a bad computer board.just have to get in there with a meter and start reading out parts,also make sure you have 240 volts coming to the dryer,you can check it at the block where the cord connects to the dryer,after that unplug it and check all the other parts for continuity and you have to remove at least one wire off of the part you're checking.also here's the sears site so you can look up your parts if you don't have this site already. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE9700AYW/3048/0151200?pathTaken=&prst=0&shdMod=MDE9700AYW good luck and wish i could help you out more
Dec 20, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
I have a Friden Model 130 Electronic Calculator and am interested in its current value?
Dear workmangk. I have a working EC 132. Your EC 130 was the 1st solid state calculator. My father used to sell & support them. I estimate a working model could be worth $US1000 +. I bought my non working EC 132 for around $400 some 8 years ago. They are difficult to obtain now. Best wishes, Gordon. Adelaide. Australia
Jul 21, 2011 | Computers & Internet
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site, http://www.vacpartswarehouse.com/Eureka-5848-Lightspeed-Whirlwind-s/1959.htm
Mar 14, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
I am looking to buy a Alcatel OT-606 with the querty keyboard. I am 76 and fnd texting very frustrating as the wrong letters keep turning. I have turned of predictive texting. Will this model solve my...
The Alcatel OT-606 is a wonderful unit and with the full QWERTY key it will solve your problem of texting with the predictive texting turned off what you press is what you get on the screen and no letters will turn. Only you have to adjust to the shift keys and the punctuations.
Hope this solution is helpful?
Compliments of the season.
Dec 29, 2010 | Alcatel Cell Phones
I have a Simplicity dryer that needs a drum belt. Mine snapped. The rest of the dryer works. Do you have a universal belt that will fit this model. It is old. I do not know where to look for the model # as...
the model #dvlr223 is missing some numbers and letters at the end, if you can find the whole model number, open the door and you should see a decal with the model and serial number, you can go to www.searspartsdirect and enter your model # and you will get an exploded view of all the parts for your dryer, try to get the part # and find it local, they charge alot for shipping
Sep 30, 2010 | GE DVLR223 Dryers
Frigidaire dryer - tub will not tumble/turn....what to do? Can read all of the model numbers....the label has a crease it in.
If the machine sounds like it is running but the drum is not turning then you most likely have a broken or unseated belt. Just open up the top of the dryer and have a look at the belt on the rear of the drum usually. Most appliance parts stores should carry belts but you would need the model number to know which belt you need. See if you can find the manual for the machine. Otherwise you'll need to have a pro come and figure out your model number.
Dec 13, 2009 | Frigidaire Electric Dryer
Cell Phones Logo
135 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
